Large drum Rucksell
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Large drum Rucksell
Post by BlackTinLizzie » Mon Apr 05, 2021 8:26 am
Selling a Large Drum Rucksell 13 39 gears 3to1 ratio.
I got this 15 plus years ago a Hershey and been stored since time to put back in circulation.
Gears look good all clean see photos
Shifter is stiff will need to be cleaned of dried up grease.
One threaded hole for the shifter is helicoiled the other is ok but might need helicoiled some day.
1600.00 obo
Photos to follow
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Re: Large drum Rucksell
Post by BlackTinLizzie » Mon Apr 05, 2021 10:26 am
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Mon Apr 05, 2021 10:34 am
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Mon Apr 05, 2021 10:39 am
1926 c.jpg (62.53 KiB) Viewed 856 times
b 1926.jpg (49.74 KiB) Viewed 856 times
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Apr 05, 2021 11:03 am
Looks like a good ring and pinion, 13 teeth on the pinion should equal a 3:1 ratio.
Sure wouldn’t take much to go ahead and peer inside....just saying.
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Mon Apr 05, 2021 1:13 pm
Internals
inside 1.jpg (46.64 KiB) Viewed 777 times
inside 2.jpg (39.42 KiB) Viewed 777 times
inside 3.jpg (45.25 KiB) Viewed 777 times
inside 4.jpg (33.36 KiB) Viewed 777 times
inside 6.jpg (45.5 KiB) Viewed 777 times
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Mon Apr 05, 2021 1:14 pm
last one
inside 7.jpg (46.44 KiB) Viewed 777 times
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Mon Apr 05, 2021 6:17 pm
Delivery to Luray Va. swap possible
Humpy57
Last Name: St
Post by Humpy57 » Mon Apr 05, 2021 8:02 pm
Would this work on a 1927 roadster truck ? Thanks
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Tue Apr 06, 2021 12:32 am
Yes, it would replace the big drum differential in your pickup.
BTW, I have no dog in this deal. It looks like a pretty good Ruckstell for that kind of money. Especially with the correct shift lock, the shifter and rod, etc. That said, based on having rebuilt over 70 Ruckstells over the years, I would replace the clutch gear and inspect the triple gears and pins, they are often worn and are cheap to replace. I also put a new bearing in every one. The correct bearing number is 7212 BECBY. Rather than buy them from the suppliers, I buy them off ebay. I prefer American made SKF, which is what the part number is for. List price is close to $200, I just bought 3 for 35 bucks apiece. The bearing and the bronze plate are critical to correct alignment of all the rest of the parts.
If this were closer to me in Montana I would have a check in the mail for it. Hard to find with a set of 3 to 1 gears for that kind of money.
Your mileage may vary. etc.
KMorford
First Name: Keith
Last Name: Morford
Post by KMorford » Tue Apr 06, 2021 1:34 am
William, email sent. Thanks Keith
Humpy57
Last Name: St
Post by Humpy57 » Tue Apr 06, 2021 7:20 am
Where are you located for pickup ?
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Tue Apr 06, 2021 8:47 am
Southern Vermont
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Wed Apr 07, 2021 1:27 pm
Thanks to all who responded
Sold to Keith
Thanks MTFCA
