Wanted: narrow trans brake drum with good lugs
Trford
First Name: Thomas
Last Name: Ford
Post by Trford » Tue Apr 06, 2021 10:03 am
Looking for a narrow trans brake drum with good clutch plate lugs.
Thank You
Tom F
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: Wanted: narrow trans brake drum with good lugs
Post by Ruxstel24 » Tue Apr 06, 2021 2:37 pm
Let me look for a good one, I have a box full of drums....
Dave
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Tue Apr 06, 2021 5:12 pm
Here’s 2, they both have some wear but not bad.
The right (dirtiest one) has smoother lugs.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Apr 06, 2021 6:43 pm
Dave - both of those are "early" drums - notice the "top hat" bushing - they are obsolete but I believe the vendors have a replacement set-up ?
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Tue Apr 06, 2021 7:02 pm
Cut the brass face off and add the three shims, same size between them.
got10carz
Last Name: Meixner
MTFCA Number: 28023
MTFCI Number: 20471
Post by got10carz » Wed Apr 07, 2021 10:18 am
I have a late 25 drum with replaceable lugs. 1 hole needs repair. $50. Steve 701 212 5009
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Wed Apr 07, 2021 10:41 am
What’s the best method for repairing that hole?
got10carz
Last Name: Meixner
MTFCA Number: 28023
MTFCI Number: 20471
Post by got10carz » Wed Apr 07, 2021 10:59 am
Adam, what I would do is bust it out to the bottom, or grind it, fill in the entire hole with brass, and machine. Use the pressure plate to transfer the hole.
