Wanted: narrow trans brake drum with good lugs
Topic author - Posts: 13
- First Name: Thomas
- Last Name: Ford
Looking for a narrow trans brake drum with good clutch plate lugs.
Thank You
Tom F
Thank You
Tom F
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Wanted: narrow trans brake drum with good lugs
Let me look for a good one, I have a box full of drums....
Dave
Dave
- Last Name: Hanlon
Here’s 2, they both have some wear but not bad.
The right (dirtiest one) has smoother lugs.
- MTFCA Number: 14972
- MTFCI Number: 15411
Dave - both of those are "early" drums - notice the "top hat" bushing - they are obsolete but I believe the vendors have a replacement set-up ?
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Cut the brass face off and add the three shims, same size between them.
- Last Name: Meixner
- MTFCA Number: 28023
- MTFCI Number: 20471
I have a late 25 drum with replaceable lugs. 1 hole needs repair. $50. Steve 701 212 5009
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Adam, what I would do is bust it out to the bottom, or grind it, fill in the entire hole with brass, and machine. Use the pressure plate to transfer the hole.
