Re-conditioned Model T connecting rods
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Tue Apr 20, 2021 10:26 am
i have several sets of -.020 and standard diameter re-conditioned Model T connecting rods ... these are from the same batch of old stock rods that i listed several weeks ago , these are obsolete inventory from a long ago closed auto parts store ... i do not know the re-builder , but the rods appear to be of very high quality ,they are X grooved and drilled for oil inlet and outlet , and have shims ...these are sold outright , NO EXCHANGE NEEDED ... price is $280 per set + $15.50 priority mail postage in lower 48 states ... actual postage amount for INTERNATIONAL sales ... please specify diameter needed ... sold in sets of 4 only ... Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Re: Re-conditioned Model T connecting rods
Post by Gene_French » Tue Apr 20, 2021 6:46 pm
as i stated in my previous listing several weeks ago the STANDARD diameter connecting rods are an excellent choice for the SCAT crankshafts... i recommend that they be checked for alignment before assembly ... as ALL rods should be checked ... i will be saving 2 sets for my own use... the rods are X grooved and i will run oil dippers on my engines ... always an optimist ...Gene French
rgould1910
Last Name: Gould
Post by rgould1910 » Wed Apr 21, 2021 11:19 am
Email sent.😀
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Apr 24, 2021 8:38 am
3 sets of -.020" diameter and 2 sets of standard diameter rods sold ... have several sets left for sale ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Apr 25, 2021 9:28 am
have 1 more set of -.020" rods and 3 sets of Standard rods ... thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Apr 29, 2021 8:59 pm
have several sets of "late" connecting rods ... these were for the stamped steel pistons and use a floating wrist pin ...they are bushed pin ends and DO NOT have the clamp bolt... they will require pistons with floating wrist pins or teflon pads to be inserted in ends of wristpins to prevent pins scoring the cylinder walls ... i am also told that this rod was used in some performance applications using chev. pistons ... not sure of the chev. piston application ... rod bores are standard and rods are X grooved and the caps and webs drilled for oil inlet/outlet ...the picture shows a standard production T rod and the "late style" rod ... these rods are of the I beam type NOT the X rods with integral dippers ... i would recommend adding the dippers available thru many parts suppliers ... price of the "late rods is $280 per set + $15.50 flat rate postage ...
gene french 970-581-2808
ironhorse
First Name: G.R.
Last Name: Cheshire
MTFCA Number: 29759
Post by ironhorse » Fri Apr 30, 2021 12:46 pm
Sen payment through Paypal
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Apr 30, 2021 8:14 pm
G.R.
rods will go out Monday afternoon ... thanks and thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Wed May 05, 2021 6:58 pm
still a few sets of standard diameter rods and standard diameter rods with bushing wristpin end ( .750" diameter wristpin ) ... 1 set -.020" diameter ... these are from the same batch of old stock inventory as described above ... these will probably be the last from this source as the remaining stock seems to be Chev. and some farm implement applications ... Gene French 970-581-2808
ironhorse
First Name: G.R.
Last Name: Cheshire
MTFCA Number: 29759
Post by ironhorse » Thu May 06, 2021 6:52 am
Rods arrived yesterday so I got greasy before supper. (Wife was only slightly irritated)
Michael A
First Name: Michael
Last Name: Abbott
MTFCA Number: 12345
Post by Michael A » Fri May 07, 2021 9:34 am
Did you get my email Gene?
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 07, 2021 7:23 pm
Michael:
sent email ... i did not get an email from you ... please re-send your's ...always an optimist ...Gene French
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun May 30, 2021 12:55 pm
to the top again ... still have several sets of standard diameter connecting rods
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Jun 04, 2021 12:27 pm
still have 2 sets of standard diameter , X groove connecting rods available ... $280 per set plus $15.50 postage in lower 48 states ... NO EXCHANGE needed ... Gene French 970-581-2808 ... paypal or check accepted
AndreFordT
First Name: Andre
Last Name: Valkenaers
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Mon Jun 07, 2021 12:12 pm
Hey Gene,
I will take one of these sets standard X grooved connecting rods and one set of standard main bearings.
I will send you an email to comfirm this.
Andre
Belgium
