SUNDAY SWAP MEET
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
SUNDAY SWAP MEET
Post by Mark Chaffin » Sun Apr 25, 2021 1:46 pm
Good morning everyone. Hope you all are doing well. This week’s Sunday Swap Meet offerings are all good used original items and a couple of new items. Description and prices are as indicated below. In most cases, USPO Flat Rate shipping will be an additional $8.50, unless stated otherwise. Payment by PayPal (preferred) or by check. Message me or call Mark Chaffin (951) 805-0928
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: SUNDAY SWAP MEET
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Apr 25, 2021 1:47 pm
1. Front license brackets $5.00 SOLD
2. Rear view mirror $5.00
3. Steering gear cover and gears (4:1) $20.00
4. Generator and starter brush assemblies $6.00 SOLD
5. Firewall mounting bracket set (square hole) $10.00
6. Main bearing bolt set $8.00
7. Miscellaneous NH carburetor parts $6.00 SOLD
8. Demountable rim bolt set (32 pieces) $15.00 SOLD
9. Hub bolts and nuts new (20 pieces) $5.00 SOLD
10. Spare tire wire wheel lock nut original $5.00
11. Valve chamber block off plate set $8.00 SOLD
12. Slow speed clutch shaft complete $15.00 SOLD
13. Clutch cam and pedal cam parts $10.00 SOLD
14. Switch wire loom (26-27) $5.00 SOLD
15. Early cast brass hood handle and brass steering column lower bracket $15.00 SOLD
16. Cutout floor pedal steel $10.00
17. Schrader brass valve stem removed from modern tubes (4) $20.00
18. Front frame cross member support bracket set $10.00
19. Brass strap ground cable and extra clamp new $3.00 SOLD
20. Generator cutouts “Ford” reproduction condition unknown $20.00 SOLD
21. Hot air pipe assortment (3) $20.00 plus $15.50 shipping.
22. Early front spindle Dodge Brothers “DB” RHT $50.00 SOLD
23. Front wheel bearings and races (3) Large (1) RHT Outer (1) LHT Outer $45.00 SOLD
24. Schrader Universal air pressure gauge brass $25.00
25. Figure 8 shackles and parts. One piece is later. $25.00
Last edited by Mark Chaffin on Mon May 03, 2021 9:37 am, edited 13 times in total.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Apr 25, 2021 2:13 pm
#23 sold to Mike.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sun Apr 25, 2021 2:33 pm
Msg. Sent for #12, I'll take it.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun Apr 25, 2021 4:07 pm
#1, #14, #19, if available. T. Woods
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Apr 25, 2021 5:28 pm
Hi Terry, #1 only still available. #14 and #19 have been sold.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun Apr 25, 2021 8:41 pm
Thanks, Mark. I'll pass. Not worth it for the one item that I need the least.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Sun Apr 25, 2021 9:57 pm
I will take #1 if still up.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sun Apr 25, 2021 11:10 pm
#1 sold to Bob. Message sent. Thanks Bob!
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun May 02, 2021 7:59 pm
Mark - put my name on # 15, please if still available - I figured you might have been at Tulare.
