Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer
Mr. T Ford
First Name: Bill
Last Name: Tofeldt
Post by Mr. T Ford » Sat Mar 27, 2021 8:52 pm
Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer.
This single wheel is for sale for pick up in Ct.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Re: Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer
Post by J1MGOLDEN » Thu Apr 01, 2021 7:18 pm
That looks like an early 1928 wire wheel.
Post by Allan » Fri Apr 02, 2021 8:37 pm
Not an A wheel. It lacks the outward pressings between the stud holes, added to strengthen the hub area.
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Fri Apr 02, 2021 10:04 pm
The very early "AR" wheels lacked the webs between the mounting holes until that design began to experience cracking where the wheel flange meets the tube for the hub, much like some have experienced with 4.50x21 wire wheels used on mid- '25 - '27 Ts.
This problem was remedied by stamping webs in the mounting flange that we are familiar with on the mid '28 -on wheel design giving greater strength in that area. This small design change remedied the cracks in that area due to flexing.
The wheel above looks like a late production (mid '25-'27) Model T wheel to me.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat Apr 03, 2021 11:33 am
The hub cap hole is bigger on the early A wheel than T. Other than that they look alike. Dan
TFan
First Name: Jim
Last Name: Riedy
MTFCA Number: 25079
MTFCI Number: 18732
Post by TFan » Sat Apr 03, 2021 1:48 pm
Something I have wondered about. Is the bolt pattern the same for the AR wheels as the T or are they the same pattern as the later A's And while I'm wondering what did the AR stand for? Jim
Post by TRDxB2 » Sat Apr 03, 2021 2:18 pm
http://www.mtfca.com/discus/messages/59 ... 1471302865
By Hap Tucker in Sumter SC on Monday, August 15, 2016 - 07:14 pm:
It is very easy to put the Model A Ford wheels on the front of a Model T Ford. Just install the Model A Hub and bearings (they fit fine). And as shown in your the photo make arrangements to lock the front wheel nut once the bearings are adjusted...... If you want to install the Model A hub cap on the wheel you need to do something because the Model T spindle is quite a bit longer than the Model A spindle. You could shorten the T spindle, put good size hole in the hub cap or even attach the hub cap to the spindle between the two nuts and don't allow the hub cap to touch the wheel. Note the Model A brake drum can be turned down if needed to clear things.
...... By the way the bolt patter is actually a 5 inch on the 5 lug Model A wheels for all Model A car wheels. From the first 1928 AR style to the normal later 1928-1928 style to the 1931 style. See the page at: http://www.randpcarriages.com/tech/axlechart.html for how to measure the bolt pattern size. The hub bolt pattern is 5 inches on the 1926-27 Model T wire spoke wheels. See: http://www.mtfca.com/discus/messages/118802/137012.html
For a comparison of the Model A and Model T wheels. It also has a photo of the AR Model A wheel which look very similar to the standard Model A wheel. And below is an illustration from the Model A Ford Service bulletins on the difference between the 1928 AR wheel and the later 1928-29 wheel that became standard.
some additional references
http://www.mtfca.com/discus/messages/70 ... 1495319779
http://www.mtfca.com/discus/messages/50 ... 1440458505
a wheel.jpg (97.66 KiB) Viewed 566 times
Mr. T Ford
First Name: Bill
Last Name: Tofeldt
Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer-Item Sold
Post by Mr. T Ford » Thu Apr 29, 2021 12:27 pm
Model T 26-27 Wire Wheel For Sale $110 Or Best Reasonable Offer-Item Sold.
The wire wheel has been sold
