Wanted: 1912 front seat parts.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Fri Apr 30, 2021 4:42 pm
Hi I have a 1912 body. I have nothing for the front seat so I am in need of seat springs, backrest, and anything else I would need to build a seat.
-- IV
Scott Rosenthal
Last Name: Rosenthal
Re: Wanted: 1912 front seat parts.
Post by Scott Rosenthal » Fri Apr 30, 2021 11:20 pm
Hello IV:
The 1912 backrest has no springs, ....the cushion wire box spring can be built to your dimensions by Snyders. You'll want to create and install the backrest and it's sides first so that your final cushion dimensions are correct. The backrest has only hand stitching where the back and sides are joined. Unless you are skilled with an industrial sewing machine, you may need upholsterer's help for the cushion, where some stitching is going through (4) layers of leather. Check with Mike at Classtique for the painted prong buttons, Send photos as you go.
Regards,
Scott
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed May 05, 2021 8:52 pm
Thanks Scott. Right now I have nothing, only a body with the box the seat sits on, no actual seat frame. Is there anyone that makes or sells the seat frame or the parts other than the springs?
Hello IV:
Regards,
Scott
Scott Rosenthal
Post by Scott Rosenthal » Thu May 06, 2021 8:37 am
Hello IV:
I couldn't find someone to make them, so I made my own. Attached shows the construction that includes steam bent hoops. These were made to my specs by Mel Draper here in upstate Ohio. The other wood parts are Maple. The spring racks were purchased from an upholstery supply house, and are identical to the OEM parts.
Regards,
Scott
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu May 06, 2021 1:00 pm
Snyder will make the correct seat spring for you, but you will need to give them the dimensions.
Wooden framed seat springs were used on touring cars until late 1911 production.
The 1912 springs are all steel construction, and the bottom of the cushion has cardboard backing (like door panels) then was covered with artificial leather, stitched to the skirt of the cushion.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu May 06, 2021 1:14 pm
If you need the sheet metal, you may try Ray Wells, aka, The Craftsman. He can probably take care of the rest of your seat needs.
Keith
