Can be Delivered to Luray
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat May 01, 2021 6:50 am
The RED MONSTER is available, 25 minutes run time on a test stand, serious power! Skat Stoker crank cross drilled, 310 Roof cam, fully balanced, full oil pressure, etc.
$10,000.00 firm, half deposit required prior to hauling. Email if interested.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Can be Delivered to Luray
Post by Henry K. Lee » Sat May 01, 2021 8:12 am
Also have an electric block (1920 and up) with all machine work completed, crank fitted and installed, shortened Model A crank, cross drilled, balanced, Model A rods with hard to find A to T bore pistons/rings, ready for final assembly, no cam or bearings. Valve seats not done as this was for an overhead build. $3,000.00 email if interested.
SOLD!!!!!! Thanks MTFCA!
Walt Wise
First Name: Walt
Last Name: Wise
MTFCA Number: 12345
Post by Walt Wise » Sat May 01, 2021 8:20 am
Mr. Hank, not only a creation of serious power, but simply a "work of art" !!! PULCHRITUDINOUS!!! You are the man!!!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat May 01, 2021 10:26 am
Model A Short Block Sold! Thanks MTFCA!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun May 02, 2021 6:47 am
Thank You Walt!
