Atwater-Kent front plate and Distributor
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Post by Gene_French » Sat May 08, 2021 6:41 pm
for sale ... i believe this to be a Model M Atwater-Kent distributor ... it is for the NON-GENERATOR engine blocks ... unit is incomplete ... that being the cam gear is missing , the points plate and points are missing the cap and rotor are missing ... the front plate casting is in good condition and the distributor shaft turns freely , the counterweights and springs and vertical shaft gear are inplace... this unit is good for parts or conversion to a modern points plate or electronic ignition ... the type M and also H caps and rotors are not difficult to locate ... priced at $75.00 + $15.50 priority mail postage in lower 48 states ...actual postage outside this area or international ...pay pal payment prefered ...Gene French 970-581-2808 email/pay pal gfrench1953@hotmail.com will add pictures
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Re: Atwater-Kent front plate and Distributor
Post by Gene_French » Sat May 08, 2021 6:51 pm
pictures ... A-K Dist.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat May 08, 2021 7:04 pm
I’ll take that Gene!
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat May 08, 2021 7:37 pm
A-K dist. is spoken for ...thanks MTFCA
