Seven original babbit rear axle thrust washers. Several appear to be NOS. $30.00 for the lot plus $8.50 shipping. Mark Chaffin (951) 805-0928
FS REAR AXLE THRUST WASHERS
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
Re: FS REAR AXLE THRUST WASHERS
Larry! You need these!
- Last Name: Meixner
- MTFCA Number: 28023
- MTFCI Number: 20471
I would like someone with knowledge explain the washers that have the spiral oil groove. Were they a jobbers item, did Ford make them? I have taken apart 2 axles that had them. They are not the same as standard washers, and even used are a different color as can be seen in Mark's picture.
- Last Name: Hanlon
- MTFCA Number: 50191
I have a pair of bronze washers with the spiral groove....
Sold to Joe. Thanks Joe.
