Holley NH center drain carburetor
Topic author - Posts: 592
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
Passages cleaned and sealed with set screws, new viton tipped needle and seat, spray nozzle, choke spring, ID tag, tested float and test run. $165 postpaid to continental USA. Email: wlkma9@gmail.com
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Re: Holley NH center drain carburetor
Hi Corey,
Do you use the full float valves like Scott Conger produces in your carbs?
- First Name: Corey
- Last Name: Walker
It has a float valve from Bob’s Antique Auto Parts.
- Last Name: Snell
Is that one Vinton tipped? I am not familiar with Bob's stuff.
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 14383
I use the viton from Bobs. They are restricted & need modification for full flow per original seats. Its worth the effort for a non drip carb.
- Last Name: Snell
So the Vinton tip is not sufficient?
- Last Name: Snell
Corey, I apologize for getting off on this float valve discussion on your thread. I have two of your carbs and not only do you do a good job, but you are a good person to deal with. Keep up the good work my friend
- Last Name: Loranger
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring
- MTFCA Number: 32239
If you still have i will take. Please let me know.
regards
george loranger
cell # 701 5208304 or email Loranger@gra.midco.net
regards
george loranger
The issue is the hole in the seat body. Its much smaller than original & flows less fuel which causes a leaner/run out of fuel @ higher demand situation.
