Early parts at Auburn, mostly 09-10
Topic author - Posts: 975
- Last Name: Gould
I will be liquidating my collection of early parts, mostly 1909-10 at the Auburn Swap meet this coming Sunday. Most parts are in excellent restored or unrestored condition.
The parts include
A Ray Wells body with top, upholstery and side curtains by Ernie Romero. Included are Rootlied front and rear fenders splash apron and a hood. The body and fenders replicate an early 1909 touring car with a roll down windshield
Three tapered front leaf springs.
One narrow gage one piece pan
One 7 river pan
Two narrow gage square hole transmission covers
One each T 191 and T 191 B drive shaft spools
One DB front axle
One 09-10 front axle complete with correct spindles, drag link and tie rod
One 09-10 steering column
One 1911 steering column
One 1911-12 drag link
A few sets of cast end radius rods, fair to excellent condition
A true 1910 driveshaft
One brass windshield frame
Two frames. One 1909-10, one 1911
Two cast cam handbrakes
One 1909-10 intake manifold
One 1909-10 hand crank
One early front motor mount
Two 403B 1909-1911 timing gear covers
Two 1910 open valve engines
One 1913 pan
One set 1909-10 Rear fender brackets
Obe brass horn
A set of early brake rods
Prices have not yet been determined. Out of respect to swap meet participants, no items will be pre sold prior to Sunday.
The parts include
One 7 river pan
One DB front axle
One 1913 pan
Obe brass horn
- Last Name: Gould
Re: Early parts at Auburn, mostly 09-10
Forgot to add
2 sets of 6 rivet rear end housings
- Last Name: Gould
Bob McDonald. There was no return email address on the message you sent thru the website so I'll answer here. The first open valve engine is numbered in the 20000s. It it in storage so I wont know until I retrieve it for the swap meet. It is a bare block with a later crank. A true 10 that hasn't been messed with, it has no babbitt in the main saddles. It has one or two freeze cracks that need repair. It's a good block not rust pitted, can't remember the bore but I believe it's standard.
The second block cannot be identified because someone in its past chisled off the date and motor number. There is a small number stamped on the rail, 15xxx and it was sold to me at the Lowe sale as a 1910. It has new babbitt and a balanced crank. It has hardened seats and new valves. It has been bored I believe 30 thou os, but no rods. The crank is ground either .020 or .030 under at the rod journals. No problems. The size of the number boss indicates it is not 09. Both blocks are genuine not made up from later blocks.
- Last Name: Rosenthal
- * REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
What is the meet location and what is the start time please?
Thx, Scott
Thx, Scott
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, 1923 speedster
- MTFCA Number: 52552
- Last Name: Gould
Respectful of those who attend the swap meet I will not promise to sell or in fact sell parts prior to the swap meet. Thanks to those who contacted me expressing an interest. But I once had a bad experience as an attendee hoping to find parts advertised only to discover they had been sold by phone to a supposed friend earlier. Someone who I had told about the sale but knew I was traveling 400 miles to see them up close.
The items that do not sell will be listed for sale on this website.
- First Name: Brian
- Last Name: Harlamoff
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
I am looking for a DB front axle and will be at the swap meet. Yes, I am driving 400 miles to get there. Do you have a space number?
Brian
Brian
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
I wish this were posted in time for me to find someone to pick some things up from that list. Anyone headed back through Indiana after the meet?
- Last Name: Gould
Looking to see old friends and make new ones. Please stop by and introduce yourself. I'll in the spaces next to the fence just behind the concession area.
Richard Gould and Bette
