Ring gear
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Ring gear
Post by Joe Bell » Sun Jun 06, 2021 12:54 pm
I was at an airport getting fuel today and noticed the gear on the drum to rewind the hose back up was a T rear axle ring gear and the 12 tooth pinion was on the driven side, this was an 80's fuel truck, who would of thought them still being used!!
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Re: Ring gear
Post by Dallas Landers » Sun Jun 06, 2021 2:00 pm
I understand that they are still made local to me and used in coffee grinders. I cant remember the details.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Ring gear
Post by Dan McEachern » Sun Jun 06, 2021 5:27 pm
Fairfield Manufacturing in Lafayette, Ind. was the USA manufacturer of replacement T Ring and Pinon gear sets for many years. Not sure if they still make them for the suppliers now or not. If you look closely at ring or pinion made by them, there will be a small "FM" stamp somewhere.
First Name: craig
Last Name: leach
MTFCA Number: 26647
Re: Ring gear
Post by Craig Leach » Sun Jun 06, 2021 6:14 pm
Yes the Hannay reel company uses a copy of a model T ring & pinion for the hand rewind used alot in the fire & cemical service. I have replaced some of them. If you look real close you will find they are cast aluminum. I bet there is a interesting story about how that came about to be a model T ring & pinion.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Ring gear
Post by Henry K. Lee » Sun Jun 06, 2021 7:05 pm
P & H electric cranes in foundries use Model T Ford small brake drums too! Really!
