Parts For Sale
Jimmie
First Name: Jimmie
Last Name: Rodgers
Parts For Sale
Post by Jimmie » Wed Jun 09, 2021 6:19 pm
JIM'S MODEL T FORD EXTRA PARTS YEAR QUANTITY CONDITION Price
ALL PARTS ARE PLUSS SHIPPING OR YOU PICK UP! (phone 231-250-5346) I live in Big Rapids, MI
Frame 14-16 1 $75
Frame 26-27 1 $50
Frame ??? 1 $50
Frane Front Croess Member ??? 1 $50
Rear End 26-27 1 $200
Engine/Transmission 26-27 1 Engine Turns $400
Spring ???? 2 Front $25 each
Running Board 26-27 2 Very Good $75 pair
Running Board 13-25 1 Solid but Rusty $40
Complete Wood Kit 15-22 1 New $500
Sheet Metal Kick Panel 15-22 1 $25
Shet Metal Back Panel 15-22 1 $35
Sheet Metal Passengers Side Panel 15-22 1 needs a big patch welded in $15
Sheet Metal Drvers Side Panel 15-22 1 $50
Sheet Meta; Cowel Panel 15-22 1 $50
Sheet Metal Dash Panel ???? 2 $10
Steering Column 26-27 1 with shaft, gears & control rods $75
Steering Column ??? 1 $25
Wish Bone ???? 2 $10
Fan Complete Assembly / with Mounting 20-27 1 $50
Fan Mounting Casting 26-27 1
Water Pump 26-27 2 need work $20
Drive Shaft ??? 1 with pinion $50
Generator 6V 19-27 2 replaced with alternator $75 each
A
Intake Manifold ??? 1 $30
Exhaust Manifold ??? 1 $50
Horn Button ??? 1 Good Condition / primed $30
Windshield Mount Bracket ??? 1 Right Side Not for Side Light $15
License Plate Bracket ??? 1 With Tail Light Capability $25
Front Body Mounting Bracket ??? 2 1 Right side & 1 Left side $50 pair
Set Floor Board Peddel Opening Trim ??? 1 Set (not for 26-27) $10
Generator Cut Out ??? 1 Worked When Changed $20
Exhaust Nut ??? 1 $5
Timer (New Day) ??? 1 Condition Unknown $25
Timer ( Roler Type) ??? 1 Condition Unknown $25
Starter Switch (Through Floor Board) ??? 1 Good $10
Switch Keys ??? 2 1 #58 & 1 #63 $5 each
Carburator ??? 1 For Rebuild / Very Rusty $25
Front Axels - With Spindels ??? 3 $50 each
Front Axels - Withouit Spindels ??? 3 $25 each
Front Spindles ??? 1 ????? $20 pair
BUY IT ALL $2,700
janweeks50
First Name: David
Last Name: Weeks
Re: Parts For Sale
Post by janweeks50 » Fri Jun 11, 2021 12:55 am
I need a complete front and rear axle for a 1915 thru 1925 T
adenautomotive
First Name: mark
Last Name: aden
Re: Parts For Sale
Post by adenautomotive » Fri Jun 11, 2021 7:25 pm
im interested in body wood , can i get some pictures? i sent an email to you also
mike catlin
Last Name: Catlin
MTFCA Number: 26310
Re: Parts For Sale
Post by mike catlin » Sun Jun 13, 2021 8:10 pm
Jim can you call me at 5863061887 thank you
Pep C Strebeck
First Name: Joseph
Last Name: M
MTFCA Number: 0
Re: Parts For Sale
Post by Pep C Strebeck » Sun Jun 13, 2021 8:29 pm
Jim,
I am interested in the frames that you have listed. I will send you a PM and call tomorrow.
