WTB Dimmer Coil
Topic author - Posts: 23
- First Name: Josh
- Last Name: Hollingsworth
- * REQUIRED* Type and Year of Model Ts owned: 1919 Touring Pickup
WTB Dimmer Coil
Early 2019 non-starter Roadster needs a dimmer coil to complete the wiring. Anyone got one to sell/know where I can get one? If not, is there a relatively simple way to simply build a tapped inductor myself to look original?
A 'youngin.
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
Re: WTB Dimmer Coil
I saw a article a while back where they took a model T coil and modified it so in effect it became a a/c magneto voltage regulator as the engine speeds up the frequency of the Magneto increases in frequency and the coil set up keeps the voltage from any significant increase. A series resistor on the dim switch will also help control headlight voltage and keep it from burning out the bulbs at higher RPM. but coil regulator would be automatic. Good Luck.
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Re: WTB Dimmer Coil
There is a used dimmer coil on the discussion https://mtfca.com/phpBB3/viewtopic.php? ... 75#p177375
It looks rough but worth a try to restore. I included some pictures indicating a how to. The wire that Lang's sells for ignition switches will work fine. You can seal your soldering with Flex Seal rubber
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe
- MTFCA Number: 32303
- MTFCI Number: 16589
Re: WTB Dimmer Coil
Sent you an email. Here are the pictures of the dimmer I have.
- Attachments
- dimmer5s.jpg (41.46 KiB) Viewed 1445 times
- dimmer4s.jpg (45.69 KiB) Viewed 1445 times
- dimmer3s.jpg (48.55 KiB) Viewed 1445 times
- dimmer2s.jpg (53.14 KiB) Viewed 1445 times
- dimmer1s.jpg (46.29 KiB) Viewed 1445 times
- Last Name: Gember
Re: WTB Dimmer Coil
Here is how it is wired on a 1926/27 non starter car switch.
- Attachments
- 26dimmer7s.jpg (47.06 KiB) Viewed 1372 times
- 26dimmer6s.jpg (40.77 KiB) Viewed 1372 times
Re: WTB Dimmer Coil
Replacing the lead wires o the coil isn't that hard - lang's has the wire and you can use Flex Steal or silicon seal to insulate.
The wires are tucked under the windings to prevent being pulled out - make a note on the two that exit the same side.
- First Name: ROBERT
- Last Name: BERGSTADT
- MTFCA Number: 1575
Re: WTB Dimmer Coil
I have some Bob
