Here is a ‘19 block I had chemical-cleaned then found a thin spot on the manifold side. It’s an excellent candidate for making a cutaway engine, non-running display engine, or if you are very ambitious you could build a 2 cylinder T engine. It would be much better to carve up this block than a perfect one! I’m looking for $50 which is less than the cleaning cost... Since its not rusty, it won’t ruin your tooling.
Clean 1919 Block to make a cutaway engine, display, or 2 cylinder.
Topic author - Posts: 1414
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
