Model TTa truck rearend
sbalsman
First Name: Stan
Last Name: Balsman
Post by sbalsman » Fri Sep 17, 2021 2:50 pm
Brass ring gear for Model TT $75 plus shipping. Also have complete rear end, disassembled, (spider gears, housings, etc) 573-768-0497
sbalsman
First Name: Stan
Last Name: Balsman
Re: Model TT truck rearend
Post by sbalsman » Fri Sep 17, 2021 2:52 pm
Model TT truck rearend brass ring gear. $75 plus shipping. Also have complete rear end disassembled, (spider gears, housings, etc.) 573-768-0497
mtntee20
First Name: Terry & Sharon
Last Name: Miller
MTFCA Number: 32583
Re: Model TTa truck rearend
Post by mtntee20 » Fri Sep 17, 2021 6:28 pm
Hello Stan,
I am interested in your ring gear, but I would like some more information. What is the condition? Are you able to email a photo to my email address? Is this ring gear a standard gear ratio, or is it a high gear ratio? Sorry, I do not know the number of teeth for each ratio, as you could quickly tell by counting the teeth.
Found it: Low speed is 7:1, and High speed is 5:1. I'll see if I can find the tooth counts. The high speed is Worm - 6 & Ring - 31. The low speed is worm - 4 & Ring - 29 teeth
Thank You,
Terry & Sharon Miller
Anthony1963
First Name: Anthony
Last Name: Andreozzi
* REQUIRED* Type and Year of Model Ts owned: 1924 TT Dump truck
Post by Anthony1963 » Sat Jul 09, 2022 10:36 am
Is the ring gears still available?
