Model TTa truck rearend
Topic author - Posts: 2
- First Name: Stan
- Last Name: Balsman
Brass ring gear for Model TT $75 plus shipping. Also have complete rear end, disassembled, (spider gears, housings, etc) 573-768-0497
- First Name: Stan
Re: Model TT truck rearend
Model TT truck rearend brass ring gear. $75 plus shipping. Also have complete rear end disassembled, (spider gears, housings, etc.) 573-768-0497
- First Name: Terry & Sharon
- Last Name: Miller
- MTFCA Number: 32583
Re: Model TTa truck rearend
Hello Stan,
I am interested in your ring gear, but I would like some more information. What is the condition? Are you able to email a photo to my email address? Is this ring gear a standard gear ratio, or is it a high gear ratio? Sorry, I do not know the number of teeth for each ratio, as you could quickly tell by counting the teeth.
Found it: Low speed is 7:1, and High speed is 5:1. I'll see if I can find the tooth counts. The high speed is Worm - 6 & Ring - 31. The low speed is worm - 4 & Ring - 29 teeth
Thank You,
Terry & Sharon Miller
Thank You,
- First Name: Anthony
- Last Name: Andreozzi
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT Dump truck
Is the ring gears still available?
