NEW 1926/27 Fordor Front Window Regulator Small Gear
Topic author - Posts: 796
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
I water jet cut these specifically for my 1926 Fordor 4 hole front window regulator, they may fit others but I won't have a clue as to which. You may have to dress the teeth slight to make them burr free, but otherwise it's a very nice water jet cut part. Cut from .125 material as the original, they are NOT hardened so they may wear out in the next 40-50 years if that is an issue. This is not a "plug & play" replacement there is some "work" required to replace this gear. $25 for a pair postage paid in the CONUS. Please respond to jandulics@gmail.com
Re: NEW 1926/27 Fordor Front Window Regulator Small Gear
Back to the top, then back on the shelf
