Magneto control switch High Tension F/S
Topic author - Posts: 1508
- First Name: Layden
- Last Name: Butler
NOS New Old Stock ( not nicely used but NEVER used or abused) magneto switch for a plain independent magneto like used on Model T accessory magneto drives, this magneto switch makes contact when in the OFF position ( opposite of most switches) to ground and kill a magneto ( will work on most makes of magnetos including Bosch, Splitdorf, Eisemann and so many others), complete and ready to use, tested and works perfectly, 1 3/4" wide. Magneto control switches are not easy to find and usually much more expensive! $99 domestic postage included!
Last edited by Layden Butler on Mon Nov 15, 2021 12:01 pm, edited 2 times in total.
- Last Name: Butler
Re: Magneto control switch Hogh Tension F/S
Just a couple left and when they are gone....Well you know what it is like to be left out!
- Last Name: Butler
Re: Magneto control switch High Tension F/S
To the top!!
- Last Name: Butler
Great deal while they last!
- Last Name: Butler
Just about gone!! Don't be too late.
- Last Name: Butler
Only 3 of these left!!
