Holley NH center drain carburetor
Topic author - Posts: 592
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
Long arm style, passages cleaned and sealed with set screws, new viton tipped needle and seat, choke spring, spray nozzle, ID tag, test run. $175 postpaid to continental USA. email: wlkma9@gmail.com
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Re: Holley NH center drain carburetor
Interested email sent
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Corey
- Last Name: Walker
- First Name: Mario
Hi. I didn’t get your email.
My email is mario dot brossard at Sympatico Dot ca.
Thank you
Thank you
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Corey
- Last Name: Walker
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Cory, please refresh my memory of the reason of the different length of arms.
Keith
Keith
- First Name: Corey
- Last Name: Walker
Keith, I really don’t know. I’ve had every Holley from 1912-26 and every Kingston from 13-26 on mine and they all fit fine. They started the short arms about the time they switched to the center drain. It took a while for them to change the casting as well, eliminating an extra drilling and plugging of one hole for the air bleed that comes out under the ID tag. At first they just put two slots at the bottom to allow the gas to drain in the center. Maybe it was to save a minuscule amount of material while they were also simplifying their production of the bodies.
