WTB Flywheel with Ring Gear for Starter & Starter
dr1960
First Name: David
Last Name: Ruedy
MTFCA Number: 50076
Post by dr1960 » Sun Mar 24, 2019 9:33 pm
collecting parts to put a starter on my 1915. found a good hogshead, looking for a flywheel with ring gear and starter.
David - Yukon, OK
1915 Model T Runabout
Michael F
First Name: Michael
Last Name: Feller
MTFCA Number: 49981
Re: WTB Flywheel with Ring Gear for Starter & Starter
Post by Michael F » Mon Mar 25, 2019 10:24 pm
I should have what you are looking for . I have several transmissions with starter flywheels. will have to check condition.
dr1960
First Name: David
Last Name: Ruedy
MTFCA Number: 50076
Post by dr1960 » Tue Apr 02, 2019 10:30 pm
Any luck checking condition of the parts? I am still looking for a flywheel with ring gear and starter.
David - Yukon, OK
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Wed Apr 03, 2019 4:23 am
I just did this on a 15. I also replaced the double stack coil ring, no notch, and narrow magnets. Lang’s has oversize peddle shafts. You’ll most likely need new triple gear pins and want to check and recharge the new magnets, thus a new set of magnet screws. You’ll need the starter drive cover, the little cup, and the special screws. The magnet keepers are also different for the newer magnets. Be glad to share what little I know, Bob at 903-824-1949.
Post by Allan » Wed Apr 03, 2019 5:54 pm
In addition to Bob's list, I would add a set of new alumimium spools on which the magnets rest. The originals are cast, and often will crack and possibly shed a piece or two when the magnet heights are 'adjusted'. The new ones are machined from aluminium stock.
You will also need a way to mount the necessary battery, a starter switch and new cabling of the correct capacity for 6 volt operation.
hope this helps.
