FS 10 tooth pinion
T Cruiser
First Name: Ted
Last Name: VanBeek
* REQUIRED* Type and Year of Model Ts owned: 27 Touring, 13 Touring, 10 Touring
MTFCA Number: 2025
FS 10 tooth pinion
Post by T Cruiser » Fri Oct 15, 2021 5:35 pm
Good usable gear,some wear and no broken teeth. I ran a 10 t. Pinion and stock r. gear on a speedster with a 36 percent Michell overdrive .I pulled all the hills in high gear and did' not use a ruxtell. I ran coast to coast twice,once in the great race and the Cal. to Detroit in 03. This makes very reliable set up. $50 plus $8 shipping Ted 503-728-3476
First Name: craig
Last Name: leach
MTFCA Number: 26647
Re: FS 10 tooth pinion
Post by Craig Leach » Sat Oct 16, 2021 1:34 am
Hi Ted if you still have it Ill take it.
T Cruiser
First Name: Ted
Last Name: VanBeek
MTFCA Number: 2025
Post by T Cruiser » Sat Oct 16, 2021 1:37 pm
Craig, I still have the gear. Call or text your address and I can send it Monday. Thanks, Ted
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sat Oct 16, 2021 11:27 pm
Ted. Sorry I didn't get back to you sooner, super busy day. Still have things to do for the tour tomarrow. I had no idea retirement would be so hectic! some days I want to drop out & go back to work. I texted you my address. How is best to pay you?
