FS 10 tooth pinion
Topic author - Posts: 221
- First Name: Ted
- Last Name: VanBeek
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring, 13 Touring, 10 Touring
- MTFCA Number: 2025
FS 10 tooth pinion
Good usable gear,some wear and no broken teeth. I ran a 10 t. Pinion and stock r. gear on a speedster with a 36 percent Michell overdrive .I pulled all the hills in high gear and did' not use a ruxtell. I ran coast to coast twice,once in the great race and the Cal. to Detroit in 03. This makes very reliable set up. $50 plus $8 shipping Ted 503-728-3476
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: FS 10 tooth pinion
Hi Ted if you still have it Ill take it.
- First Name: Ted
Craig, I still have the gear. Call or text your address and I can send it Monday. Thanks, Ted
- First Name: craig
- Last Name: leach
Ted. Sorry I didn't get back to you sooner, super busy day. Still have things to do for the tour tomarrow. I had no idea retirement would be so hectic! some days I want to drop out & go back to work. I texted you my address. How is best to pay you?
