Wire wheel looking for
Topic author - Posts: 1436
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
I'm looking for one or two wire wheels for a freinds T, He has one that has broken spokes & would like to have a spare. The hubs look to be British?
Thanks.
Thanks.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Re: Wire wheel looking for
Craig,
These folks can probably come up with some replacement spokes for you.
https://www.buchananspokes.com/
Keith
Keith
- First Name: Kevin
- Last Name: Pharis
Pretty sure this is a standard MG wheel (TC/TD?). Check the Moss Motors catalog...
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
- Board Member Since: 2013
I have spokes that are 10 and 8 inches long that I will sell for a dollar a spoke. These are new from Buchanan's. Tom 503-644-9374
- First Name: craig
- Last Name: leach
Thanks for all the quick responces. Kieth i talked to Buchanan today. Kevin Yes I think you confirmed they are, looked at Moss web will try to contact tomorrow. Tom sent email will try to get measurements tomorrow.
Thanks everyone I think we are on to a solution.
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
- MTFCA Number: 29375
looking for wire wheel
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
You should start your own wanted ad, along with saying what wire wheel you need. Besides the Ford Model T welded wire wheels, there are many other brands and types made for and fitted to Ts over the years, that could include Model A with adaptors.
1920 Dodge touring
1920 Dodge touring
- Last Name: Hanlon
- MTFCA Number: 50191
I have a bunch of T wire wheels that are pretty rough....I’ll let them go cheap.
- First Name: craig
- Last Name: leach
Hi Mark,
Wayne is the friend I'm looking for the wheels for. He noticed I had not been responding to the post. He needs to repair one & get a spare for this car. we bothe have ford wires. Thanks guys we'll keep looking.
If they are, as pointed out MG wire wheels, how many do you need ; https://www.ebay.com/sch/i.html?_from=R ... l&_sacat=0
Thanks for the info on whom the person is. Neither posting connect to one to the other, and considering how often people piggyback off other ads, did not know.
1920 Dodge touring
1920 Dodge touring
- First Name: craig
- Last Name: leach
Thanks Mark,
The wheel size seems to be the hard part to find. I'm not sure M.G. ever used a 21" wheel so these may be a highbred wheel. Yes some times people piggy back posts I did that once with out intending to kind of embarrassing when you figure out you did. Seems to be a rare wheel. I found 4 in 14" at goodguys but I don't think the oil pan will clear with those =)
Could they be older like for MG-TC, TD or maybe Singer? AACA has a British section, wonder if maybe a post there and some help might be forth coming; https://forums.aaca.org/forum/63-britis ... aguar-etc/
1920 Dodge touring
1920 Dodge touring
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
They could be but the size of the wheel was never definitely stated other than " I'm not sure M.G. ever used a 21" wheel so these may be a highbred wheel" rim width would help and also the number of splines also a picture of the hubs and hubcap/knockoff.TA,TB,TC where 19"x2.5", 48 Spoke,Mark Gregush wrote: ↑Wed Nov 24, 2021 1:42 amCould they be older like for MG-TC, TD or maybe Singer? AACA has a British section, wonder if maybe a post there and some help might be forth coming; https://forums.aaca.org/forum/63-britis ... aguar-etc/
