These are just the heads, NOS, of various applications but are very simple to adapt to most CW rotating heads, ie, Auto-Dis, Ralph Reeders Performance T Parts distributors, American Bosch, etc. You need basic machine shop skills for modifying the body base and shaft, easy to disassemble and reassemble, but on a performance T engine, the results are unbelievable. I will provide original copied instructions. A picture of the "Degree Key" is for your reference as I do not have anymore left. You can purchase on T-bay cheap.
I have found that when setting one up old school vacuum meter gauge method is still the best. This procedure is fairly simple in that you get your timing close by static means, then adjust at or around 750 RPM idle your Inch Hg vacuum pressure by adjusting timing to the maximum staying in that RPM range. After that back down to 1 less pound pressure. You are now in the ignition sweet spot. Very little adjustments are needed now. Check firing phasing in the head by static continuity. Now you can set your curve degrees by cam/compression of engine.
1 through 4 Brand New, $147.00 each with shipping. 5 through 7 Used but in excellent serviceable condition, $127.00 each with shipping. #7 is missing the center carbon from the cap. The cap, rotor, points, and condenser cost alone what I am asking. Email or Text if interested. If you do not like the product improvements in making a car better.., keep your smart comments to yourself. It is why I am quitting!
Prices Edited!!!!FS Mallory Dual Point 4 Cylinder Distributors, Majority are New
Topic author - Posts: 5339
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: FS Mallory Dual Point 4 Cylinder Distributors, Majority are New
All the Best,
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Prices Edited!!!!FS Mallory Dual Point 4 Cylinder Distributors, Majority are New
Item #2 Sold! Thanks MTFCA!
