WTB 23-25 Tall Firewall, Need a nice one!!
Channel1tv
First Name: Bryan
Last Name: D
* REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
MTFCA Number: 51668
Board Member Since: 2008
Post by Channel1tv » Thu Dec 02, 2021 3:14 pm
Need a nice clean 23-25 High/Tall Metal Firewall.
Thanks!!
Bryan
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: WTB 23-25 Tall Firewall, Need a nice one!!
Post by Ruxstel24 » Thu Dec 02, 2021 4:51 pm
I have one, I will have to get to it and make sure it’s a high one.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Dec 02, 2021 10:42 pm
The high one (wiring hole above the terminal block) is 24-25. The low one (no hole) is 23 only.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Dec 03, 2021 9:51 am
You should be more specific! Even though any high firewall will work, 1925's are different.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Dec 03, 2021 10:32 am
This is one I have. Light surface rust and the hole above the wire block as Steve stated.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Dec 03, 2021 11:13 am
As Larry stated the '25 is different in a couple areas most notably the 2 rivet patent plate - I see 4 holding that one.
* REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Post by TRDxB2 » Fri Dec 03, 2021 11:38 am
Trying to learn.... I found an old thread where you observed several different variations of the high firewall. http://www.mtfca.com/discus/messages/41 ... 1399845339
From reading the responses its difficult to understand what changes would be on the same firewall. Would help to more specific to help us grade school T students understand better. I have a high '25 but with a pressed steel stay rod (need to look again). Note: in some discussions ambiguities occur. For example in the attached link I'm not sure if referencing changes are to both, low or high '25 firewall based on the sequence of responses.
By Larry Smith on Friday, May 09, 2014 - 09:22 pm:
I've seen at least four different styles of high firewalls. The differences are trivial, but they are there.
By Jack Daron - Brownsburg IN on Friday, May 09, 2014 - 09:37 pm:
Larry,Did the 25 firewall still have the holes where the priming bell crank went?
By Larry Smith on Friday, May 09, 2014 - 10:08 pm:
They did. Also the '25 firewall has 3 holes for the felt. The 1924's had 5.
By David Chantrell - Adelaide, Australia on Sunday, May 11, 2014 - 05:55 pm:
Also the high firewalls had a riveted bracket to hold the bonnet stay rod. The later ones it was pressed out of the metal and stamped in one piece. Over here the riveted design is the 1923-24 models with the 1925 the one piece stamped design.
So the picture is of a '25 high firewall with the 3 holes for the felt
Lastly, how do these '25 firewall differences relate to models or relative production dates (I see now id plate rivets as another subtle change) or does it matter?
Channel1tv
First Name: Bryan
Last Name: D
MTFCA Number: 51668
Post by Channel1tv » Fri Dec 03, 2021 12:04 pm
I will take it Dave!
give me a call 352-638-2253
I wasn't to purist to the year as this is for a hack. I was just looking for a clean firewall.
I really like the education I get on this forum! Did not know there was a difference in the firewalls?
Best Regards MTFCA!
Bryan
