New steel parts for accessory Stromberg carbs.
Topic author - Posts: 3384
- Last Name: Morsher
UPDATE 12-30. Ready to go. $155 ppd , email me at tmorsher@icloud.com if interested , thanks, and have a better new year!
UPDATE. Finished, heading in for copper flash on Monday, so should be able to start sending first of the year. If I have you on the list, you should be hearing from me soon. If not, and you may like a set , $155 ppd. A check to me or PayPal GIfT to mis Connie.
~~~~~~~ Sure hope there is some need for these. We’ve put some considerable effort into their manufacture. Available towards the end of the month. Complete set of 5 steel parts for the accessory Stromberg OF model carb. These are often rusty and damaged, and hopefully this will get some more cores back on the road, and HELP ME SELL SOME MORE CHOKE CONTROLS , WHICH CAME WITH EVERY NEW STROMBERG CARB. EVERY ONE !
Shown is an original set of parts, and the new set will be identical ( except new looking) and will be supplied with the correct hardware to mount, and ALSO copper flash plating on the parts as original. We are testing on several carbs here for proper fit, but as in anything, some slight fitting could be required. The new sets will ONLY be sold as sets of 5 pieces for $155 ppd.
If these are interesting to you, just drop me a line and I’ll notify you when ready to ship, and as always, if you change your mind by then, no problemo. No money needed or wanted until ready to send. I’m just an old mule ( some would say ass) and really need a carrot hanging there to motivate myself! Tmorsher@icloud.com is the only way to reach me, thanks!
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: New steel parts for accessory Stromberg carbs.
They look excellent Tim, good for you for making these and I'm sure they will sell.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Nice Work Tim!
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Wow. This is a game changer. Thank you!
- Last Name: Osterman
Fantastic. Took me five hours to make the choke cable bracket last time.
BUMP. New steel parts for accessory Stromberg carbs.
Starting on these sets by Friday. Need a day off after air gauges, as I’m seeing those in my dreams. Just a bump in case you can use a set of these parts. Jack Putnam is also offering a very hard to find setup of manifolds that would really complete a Stromberg setup. Tmorsher@icloud.com thanks!
ALMOST THERE ! New steel parts for accessory Stromberg carbs.
tmorsher@icloud.com will take care of that. Wifey says I can take half a day off for Xmas, so merry Christmas to everyone !
Xmas eve update. Going in for copper flash on Monday, should be going out the first of the year. If you are on the list, I’ll be reaching out soon. If not, a quick email to -
Ready to go, tmorsher@icloud.com to reach me, $155 ppd
Bump to the top , I have about 10 sets remaining, and that will be it. Tmorsher@icloud.com in a direct email. If you want your name on a set, please write. Never a hurry for $$$$
