WTB: Speedster Steering Column Lowering Dash Plate and Wedge
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Tue Dec 07, 2021 12:27 pm
I need to lower the steering column on a speedster project.
So I need the Steering Column Lowering Dash Plate and also the Wedge that goes under the steering column-to-frame bracket.
All the vendors are sold out of them, and I understand the folks that made them don't make them now, so it does no good to back-order.
They should be pretty easy to make, but I thought I'd start here to see if someone has some they are not going to use. Thanks!
Re: WTB: Speedster Steering Column Lowering Dash Plate and Wedge
Post by TRDxB2 » Tue Dec 07, 2021 2:17 pm
Here are some DIY methods
By Bob Scherzer, Saginaw, MI on Wednesday, February 16, 2011 - 11:50 pm: http://www.mtfca.com/discus/messages/17 ... 1297950837
I reproduced these steering column angle plates from an original period piece for Lang's that might work. Bob
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Tue Dec 07, 2021 5:15 pm
Thanks Frank, I had not seen that older thread, and it has some very good ideas in it.
I think I like the metal (not wood!) wedge for the frame bracket best. I will also try the 2 bent metal straps on the dash idea, as that seems very simple. Thanks again!
Unfortunately, it seems Bob Scherzer passed away earlier this year, which was terrible news.
https://www.skorupskifamilyfunerals.com ... -Scherzer/
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Dec 07, 2021 8:06 pm
I might have an aluminum lower bracket wedge - I'll look tomorrow.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed Dec 08, 2021 1:18 am
Was there a fallow up to John McGinnises posts on Feb. 17 2011? I woudl love to see more of that speedster project.
Craig
Post by TRDxB2 » Wed Dec 08, 2021 10:09 am
Craig
This is the link to the Fed 17 2011 discussion - looking follow-ups
Some follow-up http://www.mtfca.com/discus/messages/50 ... 1437603967
Post by TRDxB2 » Wed Dec 08, 2021 11:04 am
Various steering column support brackets attached to firewall or dash
