Set of 4 coils ready for shipment right after Newyear.
Price are depending on exchange basis so that old coils must be send in advance. Below is prices exclusive VAT, which varies depending on your country.
4 coils 215,00 EUR + shipment and VAT
In case you do not have core coils to send in advance OR the ones you send do not pass the CT-2 test of the high tension circuit I will charge 30 EUR to supply a valid core.
You will normally not get the same coils back, as I have readily rebuild coils on stock to send. If you are emotionally attached to you coils, you can get them back, but the delivery time may be a couple of weeks.
This is what is done in the refurbish process:
Remove old points
Opening of coil
Replace capacitor with new with the correct dV/dT values
Retar the inner void to keep the components firmly in place during use. Tar used is the right type (asphalt)
Close coil again
Briefly clean and sand the surface of the coil
Paint top black
Treat other surfaces with linseed oil
Mount new points
Adjust points with ECCT to a dwell of 2ms and no double sparks
Feel free to contact me if you have questions.
DANIS
By-Lyngen 4, Blistrup
DK 3230 GRAESTED
Denmark
e-Mail: danis@danis.dk
Phone +45 22 27 86 51 - please respect the timezone call between 10:00 UTC - 22:00 UTC
FS - EU rebuild coils EU
Topic author - Posts: 410
- First Name: Michael
- Last Name: Deichmann
- MTFCA Number: 29116
Ford Model T 1914 Touring
Re: FS - EU rebuild coils EU
Bump to top
