WTB Axle shafts for wide track
Topic author - Posts: 86
- First Name: David
- Last Name: Herring
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 14 roadster
- MTFCA Number: 22001
- MTFCI Number: 24521
Looking to buy a pair of axle shafts in new or good shape for a wide track T.
- MTFCA Number: 14383
Re: WTB Axle shafts for wide track
A few years back, one or more T parts vendors sold them new.
Chances of finding good enough used are slim.
- First Name: David
Thanks, I have tried Snyders and Langs without any luck.
I was hoping that someone might have some NOS ones that they would sell.
- First Name: Jennifer
- Last Name: Pierce
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Pickup
- MTFCA Number: 51492
I would try Chaffins in Corona, CA.
Jennifer
Jennifer
Try Bobs also.
- First Name: David
Thanks, just tried Chaffins and Bobs but no luck.
- First Name: Matthew
- Last Name: Lewis
Hello, I actually have a couple of extre axle shafts, but I am unsure what the measurments for the wide trak are. If yoo can give me some info I can measure the ones I have to see if they are waht you are looking for.
- First Name: David
Hi Matthew, I just saw your message.
The axle shafts are each 2 inches longer than a standard model T axle shaft, but I am not sure how long the standard ones are.
At the moment I have not torn the old rear end apart either to measure the old ones but I know they are very worn from what I can see when I removed the outer bearings.
- Last Name: Cooper
If you need measurements I can measure my old set this weekend. I have the old ones from our 14 wide track . They were producing new ones at one time that my dad replaces his because of the keyways being bad at the wheel hub.
- Last Name: Rosenthal
- * REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Hello Capewake:
I would remove the existing parts for these measurements, on the off chance that you may encounter variations. I have noted this here previously, and photos that responded showed 1/4" OAL differences. Too costly a project to have this kind of boo-boo happen.
Regards,
Scott
Regards,
Scott
- First Name: David
Thanks for the advice and for offering to measure your old set.
I have been advised that the wide track axles shafts were between 33 1/32" and 33 3/32" in length.
If anyone has a pair of NOS that are will to sell please let me know, thanks.
- Last Name: Gresh
- MTFCI Number: 15762
If your still looking for these,
I have one or two sets of the reproduction wide track axles
available and could probably help you out with those.
- First Name: David
Thanks Larry, I just sent you an email.
