WTB Axle shafts for wide track
capewake
First Name: David
Last Name: Herring
* REQUIRED* Type and Year of Model Ts owned: 13 Touring, 14 roadster
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Sun Jan 02, 2022 10:17 am
Looking to buy a pair of axle shafts in new or good shape for a wide track T.
MTFCA Number: 14383
Re: WTB Axle shafts for wide track
Post by speedytinc » Sun Jan 02, 2022 10:29 am
A few years back, one or more T parts vendors sold them new.
Chances of finding good enough used are slim.
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Mon Jan 03, 2022 11:48 am
Thanks, I have tried Snyders and Langs without any luck.
I was hoping that someone might have some NOS ones that they would sell.
ModelTGal
First Name: Jennifer
Last Name: Pierce
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Pickup
MTFCA Number: 51492
Post by ModelTGal » Mon Jan 03, 2022 11:50 am
I would try Chaffins in Corona, CA.
Jennifer
MTFCA Number: 14383
Post by speedytinc » Mon Jan 03, 2022 1:39 pm
Try Bobs also.
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Mon Jan 03, 2022 3:11 pm
Thanks, just tried Chaffins and Bobs but no luck.
moddamatt
First Name: Matthew
Last Name: Lewis
Post by moddamatt » Sun Jan 09, 2022 4:10 pm
Hello, I actually have a couple of extre axle shafts, but I am unsure what the measurments for the wide trak are. If yoo can give me some info I can measure the ones I have to see if they are waht you are looking for.
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Tue Jan 11, 2022 8:41 pm
Hi Matthew, I just saw your message.
The axle shafts are each 2 inches longer than a standard model T axle shaft, but I am not sure how long the standard ones are.
At the moment I have not torn the old rear end apart either to measure the old ones but I know they are very worn from what I can see when I removed the outer bearings.
Jeepster47
First Name: Matthew
Last Name: Cooper
Post by Jeepster47 » Tue Jan 11, 2022 10:12 pm
If you need measurements I can measure my old set this weekend. I have the old ones from our 14 wide track . They were producing new ones at one time that my dad replaces his because of the keyways being bad at the wheel hub.
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Tue Jan 11, 2022 10:22 pm
Hello Capewake:
I would remove the existing parts for these measurements, on the off chance that you may encounter variations. I have noted this here previously, and photos that responded showed 1/4" OAL differences. Too costly a project to have this kind of boo-boo happen.
Regards,
Scott
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Wed Jan 12, 2022 7:26 pm
Thanks for the advice and for offering to measure your old set.
I have been advised that the wide track axles shafts were between 33 1/32" and 33 3/32" in length.
If anyone has a pair of NOS that are will to sell please let me know, thanks.
Larry
Last Name: Gresh
MTFCI Number: 15762
Post by Larry » Sun Jan 16, 2022 6:03 pm
If your still looking for these,
I have one or two sets of the reproduction wide track axles
available and could probably help you out with those.
capewake
First Name: David
Last Name: Herring
MTFCA Number: 22001
MTFCI Number: 24521
Post by capewake » Sun Jan 16, 2022 10:33 pm
Thanks Larry, I just sent you an email.
