Atwater-Kent type LA distributor
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
for sale , complete Atwater-Kent LA clip on distributor for Model T ... this is a quality period accessory ignition unit with full centrifugal advance ... unit is in good condition and complete with drive gears ... clean and lube and install ... i have used this type distributor and like the unit ... price is $125 plus $16.50 flat rate postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 gfrench1953@hotmail.com
- First Name: Gene
- Last Name: French
Re: Atwater-Kent type LA distributor
Have listed both the LA and Bosch dists. on ebay ... fair price on good distributors ... always an optimist ...Gene French 970-581-2808
- First Name: Gene
- Last Name: French
To the top , first time ... hope this sells ... have used this type ignition with very good results ... these are period correct and have full centrifugal advance ... Gene French 970-581-2808
