Holley NH center drain carburetor
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Fri Jan 14, 2022 12:38 pm
Short arm style, new viton tipped needle and seat, float, spray nozzle, choke spring, passages cleaned and sealed with set screws, reconditioned spray needle, test run. $175 postpaid to continental USA. email: wlkma9@gmail.com
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
MTFCA Number: 31662
MTFCI Number: 23677
Board Member Since: 2014
Re: Holley NH center drain carburetor
Post by SurveyKing » Fri Jan 14, 2022 3:47 pm
Corey, can you tell me when the short arm verses the long arm change was made and why?
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Fri Jan 14, 2022 6:08 pm
Around 1923, the same time the center drain started but there was some overlap where the long arms remained for a while. At first the added 2 slots to the bottom of the casting to let the gas drain, then they changed the casting altogether to make it so the air bleed under the id tag required only drilling one hole. I’m not sure why they changed. Maybe to save a little material since they were simplifying it. The old style air bleed had one crossways hole drilled then plugged.
Corey Walker
First Name: Corey
Last Name: Walker
MTFCA Number: 51502
Post by Corey Walker » Fri Jan 14, 2022 8:24 pm
Carburetor is sold.
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Post by SurveyKing » Sat Jan 15, 2022 9:50 am
Good info Corey, so for my 1924, which is correct, the long or short arm?
Dan
MTFCA Number: 14383
Post by speedytinc » Sat Jan 15, 2022 10:18 am
short. short.
