Wanted Kwik-Poly even partial cans
Topic author - Posts: 1287
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Does anyone have any kwik-poly. ? I need about 1/4 or a little less, of the original amount in the kit. As long as both parts are still liquid, it will still work for what I need it for.
dobro (at) artelco.com
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Wanted Kwik-Poly even partial cans
I wish they would still make the stuff!
- First Name: Dale
- Last Name: McMurry
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
- MTFCA Number: 2213
- MTFCI Number: 5309
Smiths Penetrating Epoxy will do the same thing.
- MTFCA Number: 52564
1920 Dodge touring
1920 Dodge touring
- Last Name: Gresh
- MTFCI Number: 15762
I have a couple extra cans if you haven’t found any.
The cans are probably about 3/4 full and have been stored in a paint cabinet. They are sill liquid and should be fine. If you need them, message me your address and I can send them out in the morning.
- Last Name: Wrenn
Thanks Mark! Lots of good epoxy's there... I'd choose either the Smiths or the "Total Boat" Penetrating Epoxy. They both seem
similar. For me, the important part is having it thin, then expanding. Kwik Poly was great for that, once when I temporarily used it to tighten spokes until replacement, I was shocked to see how it even flowed down from the tenens in the felloe down INSIDE the spoke and then came out of an almost indistinguishable fine crack in the spoke to seal it too! Figured that may have saved the spoke from completely busting before I could send it to Stutzmans.
- Last Name: Brown
Larry, I sent you an e-mail.
- Last Name: Brown
Mark, thanks for the link. There are some of those products I will need to try.
Larry had enough for my project. Thanks Larry, I owe you one.
