3-11 1 SOLD ! Front lowering brackets for sale
Topic author - Posts: 3384
- Last Name: Morsher
SOLD. OK, I FLUNKED MATH, MANNERS, PATIENCE AND SEVERAL OTHER SUBJECTS. I FIND MYSELF WITH ONE LAST PAIR OF THESE. JUST CLEANED MY WORKBENCH OFF, AND THERE THEY WERE! ( thankfully, I still have all my fingers, but can still only count to ten ). SO, ONE LAST, LAST PAIR OF THESE ARE AVAILABLE, $285 ppd to your door. HE WHO HESITATES IS LOST ! Tmorsher@icloud.com in a direct email, thanks!
2-14 update. All gone again. WE SENT A PAIR OUT BY MISTAKE SO WE HAVE ONE COMPLETE PAIR OF THESE AVAILABLE $285 ppd tmorsher@icloud.com to reach me. Tmorsher@icloud.com Always glad to take easy payments. Thanks.
EVERYONE THAT REQUESTED A PAIR OF BILLETS OR A MACHINED PAIR HAVE BEEN NOTIFIED. IF YOU DIDNT HEAR FROM ME, I MAY HAVE MISSED YOU, SO PLEASE EMAIL ME , direct to ; tmorsher@gmail.com ASAP. At this point, I have a couple sets not spoken for, For a machined pair with hardware , $285 ppd. UPDATE. THE EXTRA TWO SETS SOLD QUICKLY BUT I HAD SEVERAL MORE INQUIRIES. I GOT AHOLD OF THE STEEL SHOP AND THEY CAN SPIT OUT SEVERAL MORE SETS. SO, A COUPLE MORE PAIRS ARE AVAILABLE. PLEASE READ UPDATE AT BOTTOM OF THREAD. I have a couple sets of these getting cut out of steel. I had an original pair of these years ago, and they make a neat , strong setup. Lowers the front end 3” , if you reverse the front spring eye, 4”. 26-7 spindles….you see where I’m going. Tmorsher@icloud.com just a one time deal so don’t procrastinate getting with me. Need no money until done.
Re: Front lowering brackets for sale
This very precise accurate scale drawing should ‘splain how they work. I believe from memory this doesn’t interfere with the steering rods , which is a big issue in some lowering ideas.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
From the drawing I can see you assisted in the moon landings! Thank God Tim had a hand and pencil in it!
Plus or minus a couple whiskers !
Looks like your with longer bolts and radius rods - besides the additional drop
Thanks Frank. The lower picture is them. Is a lot cleaner looking to install the hex bolt from above and thread the lower arm to match, then no nut to hang below the axle.
- First Name: Kevin
- Last Name: Pharis
So... where do you order the 11/16” shank bolts...? I’ve resorted to making my own, rear axle shafts are the perfect material
My originals had smaller stock bolts and a bushing would take up the gap in the axle hole. If I recall, two spring shackle bushings were just about right. The holes reamed a bit. Our grandpappys weren’t dummies. It’s up to the guy who finishes them.
- Last Name: Rogers
- Board Member Since: 2013
Email sent...
Re: UPDATE. Front lowering brackets for sale
PLEASE NOTE……..YOU WILL GET BURNOUTS WITH SQUARED EDGES. IF YOU WANT RADIUS ON EDGES, THAT WILL BE ON YOU. A GRINDER OR OTHER METHOD, BUT ON YOU! The highly percison drawing shown below should explain that.
Re: 2-3-22 UPDATE. Front lowering brackets for sale
Please read updat at first post. I still have a couple pair of complete pairs , $285ppd for machined with bolts. Ppd to your door. A direct email to tmorsher@icloud.com if interested. Thanks!
2-7 update see above.
Re: 2-7- 22 UPDATE. Front lowering brackets for sale
And, I’m running behind a bit. A new cutter is still lost in the blizzard somewhere. It’s replacement came this AM
These will be heading out tomorrow . Thanks! 2 pairs still available .
Re: 2-9- 22 UPDATE. Last pair Front lowering brackets for sale
Just one pair left. Tmorsher@icloud.com to put your grandsons name on them
Re: 2-9- 22 UPDATE. All SOLD ! Front lowering brackets for sale
Great news, all dozen pairs are gone to new T projects. That’s exciting to me, and hope it is to you.
Re: 2-14- 22 UPDATE. One pair available ! Front lowering brackets for sale
WE SENT OUT ONE PAIR OF THESE BY MISTAKE. SO, WE HAVE ONE FINISHED PAIR AVAILABLE FOR SALE. $285 ppd to your door tmorsher@icloud.com in a direct email please. THANKS!
- First Name: Brian
- Last Name: Harlamoff
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
I will take the machined lowering brackets if they are still available.
Brian in Santa Cruz
Brian in Santa Cruz
Re: 2-14- 22 UPDATE. SOLD ! Front lowering brackets for sale
Sold to Brian thanks
- First Name: Dean
- Last Name: Brevit
Set will be going back to Tim as I'm no longer going to use. Tim graciously offered to refund me when he gets them back (I have to get them first).
He will have another set if somebody missed out.
Just found another pair on the bench. Honest, last pair ever from this bum. Tmorsher@icloud.com in a direct email, thanks!
- First Name: Brian
- Last Name: Healey
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1915 Canadian touring 1915 roadster boat tail speedster
Re: 3-11 1 pair available ! Front lowering brackets for sale
Tim I sent an email this morning. Interested in the last set
