Wanted: Murphy fasteners as pictured
Topic author - Posts: 93
- Last Name: Debaugh
- * REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
Hello,
Looking for rear curtain Murphy fasteners as pictured .
Please contact me at 410.336. one seven two eight or at my site www.oldslots.com.
Thanks, Larry
Thanks, Larry
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Wanted: Murphy fasteners as pictured
Do they have to be black ?
I have some nickel ones that do not have the M.
I will have to look for the black ones, I think I should have some. Not sure of the M on them either.
Dave
Dave
Dave, thanks for checking, the ones I need are brasss with the M stamped on them..... need 3 more for the rear curtain of my 10 Tourabout .... larry
- Last Name: Hanlon
No problem Larry.
I don't have any brass ones.
I guess you're picture is brass, but looks black on my phone.
Snyder's has brass ones with the M for $1 each.
The ones Snyder’s have do not have the circle with the M in the center ... that would have been too easy... I’m sure someone out there have a couple only need 3 more. I have the ones from Snyder’s but an engraver wants $200 to do 10.... Larry
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
i will have to count!! how maney does it take for a complete top & side curitens ???. i just need one set. charley
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
I wonder if the top off of these could be removed and put onto the desired base - very pricey, though!
https://www.restorationstuff.com/ecomme ... ts_id=1377
- Last Name: Morsher
I think I can he.p you, Larry. Drops me a reminder note next week, tmorsher@icloud.com I cannot check until then. I have thousands of used fasteners. T
Thanks for the reply’s... I have plenty of the solid figure eight two hole version and I have tried to swap the twist part with no luck........ six are needed for the rear curtain, 3 per side ..... larry
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Larry-
What are these going onto?
I have never seen a Murphy brand fabric attach type of fastener.
Most that I have seen with the M are the flat type with backing burr that rivet onto fabric.
The other fabric attach fasteners have no M.
Keith
Keith
- MTFCA Number: 121
- MTFCI Number: 16310
I thought the fasteners used in 1910 were cast, not hollow like the one in the picture.
- Last Name: Shaver
larry is right. 1910s are cast.i went to the 1910 pile here the pics.if you have any more ???? call. charley
Thanks for the reply... the ones pictured are for my 1910 Tourabout.... was an unrestored original car I am restoring, Top was ruff but original , one side of the rear curtain that attaches to the buggy rail was missing. The Murphy’s pictured were on the other side, I have seen and have the ones Charley posted pictures of and they were used on the early t’a also.... I would like to find 3 or more of the ones pictured. Thanks Larry
- MTFCA Number: 121
One thing you must be careful of is the fasteners in some places were attached to the bow drill before the bow drill or top material was sewn onto the top.
Thanks.... the two tabs (points) are thru all of the material with the backing plate visible trim the inside on the side I have.... larry
