TT, T, & AA Parts for sale
Topic author - Posts: 64
- First Name: Jack
- Last Name: Leonhardt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
- MTFCA Number: 23188
- MTFCI Number: 19556
Hi Speed TT rear end (refurbished) great shape with hyatt bearings on one axle $450.00. Four (4) salvageable TT brake backing plates $50.00 for the pair and $40.00 for the other pair, Ruckstell TT rear end housing and some associated components $250.00, Three (3) pairs of TT rear axle housings $40.00 per pair, Two (2) low speed worm drive gears(1043) and worm gears (1044) $40.00 per set, TT brake drums $50.00 each, Four (4) flat style 1928 wire wheel hubcaps for AA $120.00 each, Two (2) Cone style AA hubcaps $100.00 each, Three (3)1928 AA front wire wheel hubs $120.00 each, Four (4) 20" wire wheels for 1928 Model AA $125.00 each, Two (2) 26/27 Model T wire wheels w/ hubcaps & lug nuts $240.00 for the pair, Two (2) 26/27 Model T wire wheel front hubs $240.00 for the pair, Arvin heater complete (aged original cardboard packaging) $275.00, 6 volt cow horn $50.00, Two (2)sets of front Hassler shocks $45.00 per set, New Hassler bolts & nameplates $60.00, "No name" front shocks for T or TT $40.00, Two (2) TT rear radius rods $50.00 each, Stromberg OF carburetor $400.00, Acorn style Model AA (1928/1929) wheel nuts $3.50 each, TT torque tube $40.00, Four (4) TT running board brackets (extra holes drilled) $75.00, Stewart speedometer mounting flange (part number 1070) for Model 160 speedometer $125.00. Text 920-226-1005
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
- MTFCA Number: 49514
Re: TT, T, & AA Parts for sale
Hi Jack, I'll take the 2 26/27 wire wheels and the TT torque tube, can you bring them to the spring meeting on Sunday? If not I can stop up by you.
- First Name: Jack
Billy,
Rich Edler will bring the items to the meeting -- thank you.
Regards,
Jack
Regards,
Jack
- First Name: Charlie
- Last Name: Coleman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
- MTFCA Number: 51002
Hello I’m interested in 2 of the AA spoke wheel flat hubcaps. Can you send any photos. Many thanks Charlie
707 391-5324
707 391-5324
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
- MTFCA Number: 32518
I don't know the seller and haven't seen the gears, but if they are in "great shape" they are a steal at $450. These Hi Speed 5:1 gears are difficult to find. I have two extra sets in good shape, but I would not part with either for less than $1,000.
If you need a set of 5:1 gears for a TT you need to verify that they are in great shape through pictures, then don't hesitate to buy for use or spares.
There is a fellow who has made these in the past, and they are like new, but he is not making them now and when he does the price will be over $1,800 / set!
- First Name: Keith
- Last Name: Gumbinger
- MTFCA Number: 4661
- MTFCI Number: 6866
I know Jack Leonhardt, the fellow who is selling these parts quite well, and can vouch for him. His part descriptions will be very accurate.
Keith
Keith
