Cap, rotor, and points look ok. The two gears were attached to the unit when purchased years ago. Shaft turns, seems to be missing a short shaft to connect with the cam I am not sure. I don't see a name plate or markings to ID the unit. $ 300.00 + ship. Gary. ganderson7atcomcastdotnet
651 - 776 - 8387
Acc Distributor and Front plate
Topic author - Posts: 73
- First Name: Gary
- Last Name: Anderson
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1918 Roadster Rajo
- MTFCA Number: 13395
- First Name: Todd
- Last Name: Manoff
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1923 Speedster
Re: Acc Distributor and Front plate
Gary,
This is a Atwater Kent Unisparker set up. I believe the the distributor is a Type F Unisparker.
Atwater Kent also made same T front plate set up with there Type K distributor. Both are supposed to be used in conjunction with there matching Type F or Type K wood coil box.
Todd
Todd
- First Name: Gary
Thanks Todd for the information. Gary
- First Name: Gary
New price $ 225-00 + $ 10.00 shipping lower 48.
- First Name: DAN
- Last Name: MCEACHERN
Nice this about this one is it is a way to put a distributor on a non-generator block. You don't see these for sale very often.
