Spiral wound rear axle roller bearings F/S
Posted: Sun May 01, 2022 4:41 pm
by Layden Butler
USED rear car axle spiral wound roller bearings part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers, price is $75 each, domestic postage is a flat $15 per order regardless of number ordered.
Re: Spiral wound rear axle roller bearings F/S
Posted: Sat May 21, 2022 2:13 pm
by Layden Butler
Happy purchasers to date! Limited number still available and then they will be gone.
Posted: Sat May 21, 2022 3:59 pm
by CudaMan
I have what I need of these, but many don't - Thank you for making these available, sure hope that those that need them take advantage. :)
Posted: Sat Jun 04, 2022 1:07 pm
by Layden Butler
Maybe last call for these before they are gone!
Posted: Sat Jun 04, 2022 1:24 pm
by David Tipton
Layden,
Just set you an email.
Dave Tipton
Posted: Sat Aug 13, 2022 8:11 pm
by Layden Butler
One more time around!
Posted: Tue Feb 07, 2023 9:25 pm
by Layden Butler
This may be the last time offered!
None have ever been returned!!
Posted: Wed Feb 08, 2023 1:11 am
by MarkS
Email sent
