Stevens Tapered Reamers??? UPDATE
Topic author - Posts: 4111
- Last Name: Hatch
- MTFCA Number: 49974
I have been getting a number of inquiries for my Stevens Tapered Upper Reamers. I am considering another run. Due to increased cost the price is going to be in neighborhood of $250.00 + shipping.
I will need at least 7 orders for this to happen.
Email me at address in pictures to reply.
If I get enough interest I will look into another run of reamers/taps.
Thanks Dan
I HAVE 2 REAMERS LEFT as of 5/23/22.
If you want one speak now.
Thanks Dan
- Last Name: Tannehill
- MTFCA Number: 49460
Re: Stevens Tapered Reamers???
You know I’m in.
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
Dan, I'll take one. Will also send you an e-mail.
Come on gals & guys we need to get to at least 7. If you have an original reamer you’re on borrowed time plus you should see the one Dan has reproduced. It’s longer so that it can be sharpened, really a quality piece and yes I’m being selfish I’d like to have at least one more before they are not available.
- Last Name: Hatch
Up to 4 need 3 more to sign up .
- First Name: BRIAN
- Last Name: CRESS
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
- MTFCA Number: 29555
- MTFCI Number: 15565
Hi Dan,
Russ Potter has asked me to add his name to the list.
Just two more to go!
- Last Name: Hatch
Brian got your email and another one too. We are at 6. Thanks guys . Dan
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
- MTFCA Number: 2406
- MTFCI Number: 22213
Dan, Are they the straight taper, or the spiral cut that draws itself into the hole?
1922 Coupe , 1926 Touring
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
I'm in for one,
Brian Dowell
Brian Dowell
Life is Good, be nice.
- Last Name: Hatch
Straight
- Last Name: Hatch
Reamers will be ordered today!
I am checking on the reamer/taps.
Stay tuned for more updates. Thanks Dan
Dan thanks for doing this.
Hey Forum if you even think that you may need a reamer for your Stevens tool, you need to get in contact with Dan so he can add to the order before it’s too late. More than likely this will be a last chance opportunity. Best John
- First Name: steven
- Last Name: davidson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
- MTFCA Number: 51591
Dan, got your email, thanks for doing this.
- Last Name: Brown
I agree with JTT3. If you think you may ever need another set, I would get on this boat before it sails. Even with proper use the reamer's do not last forever. The original taper reamer's are made of unobtanium. Dan's taper reamer's have been the only likely way to make a Steven's Front Axle tool complete and usable. His reamer's are top notch items. Thanks Dan,for making them available one more time. Now I can have a complete back up set.
- Last Name: Wing
- * REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout, 1911 touring, 1913 touring, 1924 coupe, 1925 touring
- MTFCA Number: 29346
Hi Dan,
I just ran across this threat and would like to be added to the list if I'm not too late. I sent you an e-mail.
Thanks,
Mark Wing
Thanks,
Mark Wing
- Last Name: Wing
That should read "thread".
- Last Name: Hatch
Back to the top. Also see reamer/tap thread. You need to let me know if you want one too.
Tapered readers all most gone.
- First Name: nigel
- Last Name: hugo
- * REQUIRED* Type and Year of Model Ts owned: 1911 T touring car
Hello Dan, if you have a complete kit available, the stevens tool, the tapered reamer, and the lower tapping tool. please can you let me know what you have. Many thanks. Nigel Hugo.
- Last Name: Hatch
As of right now I think there is one tapered reamer left, reamers/taps, upper & lower inserts. Jack May have some frames. Thanks Dan
Hi Dan
I had emailed my desire for a tapered reamer and am "on the list" I believe...are you wanting payment or just another promise to buy one...I hope to not miss out. Thanks.
NH Full Flow Float Valves
- Last Name: Hatch
Scott you are on list. Waiting for the reamers to be made. I will start notifications when I get them in hand. Thanks Dan
- Last Name: hardiman
- * REQUIRED* Type and Year of Model Ts owned: 26 coupe
Hi Dan
You have 2 threads:
1 tapered
2 front axle
Are they the same? If not what's the tapered unit used for?
John
You have 2 threads:
1 tapered
2 front axle
John
- Last Name: Hatch
Not the same. Takes one of each to fix axle. Pictures worth 1000 words
https://www.youtube.com/watch?v=7DNGT7P79vg
- First Name: Randall
- Last Name: Strickland
Dan here's one I made a while back doing it with axle still in car
https://www.youtube.com/watch?v=v9YJvzcyNHw&t=10s
- First Name: nigel
- Last Name: hugo
Dan, I am in for the tapered reamer, the drill and tap for the bottom hole.
Thanks, Nigel Hugo.
Thanks, Nigel Hugo.
- Last Name: Hatch
Re: Stevens Tapered Reamers??? UPDATE
See first post for updates.
- Last Name: Hatch
2 left . Get on list now or lose out.
- First Name: Brian
- Last Name: Dowell
- MTFCI Number: 205
Dan
I was on the list I believe for the reamer! I would also like the reamer tap.
Please let me know!
Brian
586 864 5110
Please let me know!
Brian
586 864 5110
- Last Name: Hatch
Email sent . Thanks Dan
- Last Name: Seress
- MTFCA Number: 27707
Dan, how much will it cost me for an upper tapered reamer and for the lower reamer/tap.
Frank
Frank
- Last Name: Hatch
Prices are in first post of each thread.
Upper $250.00
Lower $200.00
+ shipping
If you want a set email me at address in pictures ASAP.
Thanks Dan
Upper $250.00
Lower $200.00
+ shipping
Thanks Dan
Dan, will we be able to purchase tapered and threaded inserts from you when the reamers are ready?
- Last Name: Hatch
Yes I have them in stock
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Have a couple left
- Last Name: Hatch
Still have one set left!
- Last Name: Seress
Dan, do you have any tapered reamers left? I would like one please. Also a couple set of inserts to go with that when the reamers are ready.
Frank
Frank
