wood coil box lid
Topic author - Posts: 174
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
wood coil box lid
Hi From Iowa! Does anyone know where I can get a new cover made for the Hince wood coil box for my '12 T? My local wood guy was going to make one but found that he did not have the correct blade to make a perfect joint at the corners! Thanks John
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
- MTFCA Number: 8377
- MTFCI Number: 22437
Re: wood coil box lid
John Anderson, Gerry, N.Y
Hi From Iowa! Is John Anderson RV s brother? How do I contact him? Thanks John
- Last Name: Gagel
Yes he is RV's brother.
jpautowood@gmail.com
- First Name: Rob
- Last Name: Chatten
Hey John, You could try Mel in Ohio he does them . Or if you want to ship it Canada us Canadian could see if the same guy will do another 1 done for you . John Bell had it done for you.
I made my own, exact to the last detail, copied from an original. Then I discovered that my box was almost 1/8" wider, and the lid wouldn't fit. You need to be careful.
