11-12 carb adjustment rod fs. Sold
CTLeonard
Last Name: Leonard
Post by CTLeonard » Wed May 18, 2022 11:54 am
Adjusting rod with brass knob and brass two hole bezel. 19" long. Could use a little more polishing to be brilliant. 75.00 plus shipping
1913Runabout
First Name: Brian
Last Name: Harlamoff
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Re: 11-12 carb adjustment rod fs
Post by 1913Runabout » Wed May 18, 2022 6:00 pm
Original or reproduction?
MTFCA Number: 121
MTFCI Number: 16310
Re: 11-12 carb adjustment rod fs. Sold
Post by Original Smith » Thu May 19, 2022 11:08 am
The year is incorrect.
CTLeonard
Last Name: Leonard
Post by CTLeonard » Thu May 19, 2022 11:51 am
Could you enlighten me please? Not meaning to misrepresent, especially to the guy that just bought it. My main info is Lang's and Snyder's. They show 9-10 had the four hole mounting plate. 11-12 has the two hole plate. 13 was on her own, 14 went to the flat two hole. As I said please enlighten me, I will hold shipment on this item until I can find something different. Thank you
RGould1910
Last Name: Gould
Post by RGould1910 » Thu May 19, 2022 4:14 pm
Seems right to me. Except some late calendar year 1911s into 1912 had a pressed steel bracket that resembles the one you're selling. I can't load a photo on a quick reply. I think Langs carries a reproduction, though.
Post by Allan » Thu May 19, 2022 9:13 pm
The devil is in the detail. I suspect it is a reproduction. The fork piece is welded to the shaft. The original rods are forged and the fork is part of that forging. The 1913 one listed separately shows the forged end of the fork.
I could be wrong.
