Battery carrier
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
Battery carrier
Post by Melba Nolan » Mon May 23, 2022 7:06 pm
ImageFor sale. Battery carrier. Part #5150A as shown in Langs book. $40.00 plus freight.
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
MTFCA Number: 31662
MTFCI Number: 23677
Board Member Since: 2014
Re: Battery carrier
Post by SurveyKing » Mon May 23, 2022 11:25 pm
Could you please post the measurement of the inside width (side to side) of the carrier? There is a difference between those that were used with the metal battery box. Starting sometime in 1923 the battery bracket changed to part number 5150 B to accommodate the steel battery box. Prior to that, the bracket part number was 5150 which is narrower. I have one of each the difference is about 1/4". The brackets I have seen do not have a part number on them, so to tell for sure we need that measurement. Thanks
Dan Snell
Danielsnell2@twc.com
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: Battery carrier
Post by Melba Nolan » Tue May 24, 2022 11:12 am
Its about 9 1/2 if you measure on the center bracket
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Re: Battery carrier
Post by SurveyKing » Tue May 24, 2022 4:05 pm
The steel battery box measures 9 1/2 by 7 3/4" so the dimension side to side needs to be 8 inches to accommodate it. What is the side to side measurement?
SurveyKing
First Name: Daniel
Last Name: Snell
MTFCA Number: 31662
MTFCI Number: 23677
Re: Battery carrier
Post by SurveyKing » Wed Jun 01, 2022 10:48 pm
At least it should have a width of 7 7/8 to accommodate the steel battery box. If you still have it for sale, please check this measurement, I may be interested. Thank You
Re: Battery carrier
Post by Allan » Thu Jun 02, 2022 12:57 am
The carrier is missing the bent outwards tabs at the top of the U shaped strap. These are needed to accept the battery hold down clamps. They can be made and welded back on. Just a heads up to avoid any disappointments.
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: Battery carrier
Post by Melba Nolan » Thu Jun 02, 2022 10:29 am
thank you I didn't know that
Re: Battery carrier
Post by Allan » Thu Jun 02, 2022 8:39 pm
Glad to help. Here's what it looks like.
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: Battery carrier
Post by Melba Nolan » Thu Jun 02, 2022 8:55 pm
it looks like mine has that at the end, which is different from yours
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: Battery carrier
Post by Melba Nolan » Wed Aug 10, 2022 6:58 pm
move to top
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Re: Battery carrier
Post by Ken Buhler » Thu Aug 11, 2022 12:20 am
And the bottom strap is worn through, which has to be replaced.
Work honestly
Stay true to your word
Get the job done right
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: Battery carrier
Post by Melba Nolan » Tue Aug 16, 2022 6:32 pm
I don't see a bottom strap
Re: Battery carrier
Post by Allan » Tue Aug 16, 2022 7:06 pm
There are additions to the carrier as well. Ay each mounting point an extra piece has been welded in to allow the carrier to be hung from the top of the frame rail rather than bolted to the sides of the rails. I have no idea why this was done.
