Found - Thank You - Main caps and bolts/nuts
Topic author - Posts: 253
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
- MTFCA Number: 26904
FOUND LOCALLY. Thank You
Last edited by Chad_Marcheese on Sun Jun 05, 2022 3:31 pm, edited 2 times in total.
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
- MTFCA Number: 17802
Re: WTB : Main caps and bolts/nuts
Chad, I have a box full of main bolts with nuts that are used but appear to be good. I also have a set of re-babbetted main caps that are .010 over. I am in Rhinebeck. You are welcome to come and look for yourself.
- First Name: Chad
@John iaccino, Thank you for the offer. I don't think the rebabbitted caps will suit me for a new build with a Scat crank. I may hit you up on bolts though.
No problem
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Chad:
the .010" "over" caps that John has should work for your application , assuming that you have re-babbitted the block and have to linebore ... opposite to the terminology i would use , the "over size" term for bearings in automotive use seems to mean a smaller diameter than "standard " ... so i would assume the .010" oversize diameter would be 1.240" to fit a 1.2385 diameter crankshaft ... your standard Scat crankshaft will be 1.2485" diameter ... this allows for boring .005" per side to finish diameter ...always an optimist ...Gene French
Chad, just sent you a PM. I have a set of main caps that need to be re-babbetted.
- First Name: Gene
- Last Name: French
Chad:
not sure what is meant by the term " uncut " main caps , but if you need re-babbitted caps that are not bored then i can supply a set of re-babbitted caps that are cast at 1 1/8" diameter and .03" excess material on each thrust surface for finish boring and cutting of the thrust clearance ... always an optimist ...Gene French
- First Name: Chad
What I meant by uncut was not filed on the mating surface.
Still looking for a set of reasonable cores and bolts. Thank You
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
- Board Member Since: 2013
I have a full set of main caps and bolts. I am out in Portland, Oregon. If you can't find them in your area, give me a call at 503- six44- nine374
Tom
Tom
- First Name: Warren
- Last Name: Webb
Sent you an email a week ago
