This is a full frame off restored car. Excellent running, tour proven, very reliable.
Engine fully rebuilt
New babbit bearings
Crankshaft and flywheel dynamically balanced
Crank reground
Stipe 250 camshaft
McEaschern timing gears
.060" oversize aluminum pistons
Adjustable lifters
Hardened valve seats
Runs very smoothly and pulls hills great
Ford low head
New mag coil and recharged magnets
Starts and runs perfectly on mag
Transmission
All new transmission Drums from Dave Nolting
Floating transmission shaft
Operates smoothly. No band chatter
FULLY REBUILT RUCKSTELL AXLE
Shifts flawlessly
Fun projects pinion bearing
Stewart Warner 160 Speedometer (Russ Futstnow restoration)
Ford Bumpers
Fox Locking steering wheel with keys
Running board tool box
Bergs radiator
Brass radiator shell
Restored original ford ignition
Stock ignition fully restored
All wheels have been rebuilt with spokes From Stutzmans. All 4 tires replaced a few hundred miles ago
Classtique upholstery kit installed
Asking 12k
Stephen
For sale: Restored 26 coupe Ruckstel axle and other accessories
Topic author - Posts: 364
- First Name: Stephen
- Last Name: Heatherly
Re: For sale: Restored 26 coupe Ruckstel axle and other accessories
Please move this to the vehicles section. I posted in the wrong place.
Thank you
Thank you
- First Name: Jay
- Last Name: Behm
Hi,
What is the overall height? I have a low door height and I need to check that first. Also, is the paint and exterior in good shape. It looks dusty and dull in the pics. Also, any pics of the interior? Thank you.
Jay
Jay
