Found Wanted to buy radius rod ball socket for 4 dip pan Found
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Thu Jun 16, 2022 3:20 pm
Found
Ok so I am going to try and straighten my 4 dip pan where the ball socket mounts. The one that is now mounted is just too bent up to mess with, along with the socket being too worn. At some time the car was hit or damaged, pushing/bending it out of shape.
I am in need of a "GOOD" socket, preferably not too worn in the ball socket. I need one that I can work from/with to get the shape close and then be able to rivet/braze back on.
1920 Dodge touring
sweet23
First Name: Darryl
Last Name: Bobzin
MTFCA Number: 27211
Re: Wanted to buy radius rod ball socket for 4 dip pan
Post by sweet23 » Thu Jun 16, 2022 5:45 pm
Langs had some NOS ones at one time.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Thu Jun 16, 2022 5:59 pm
Call Lang’s they may have one. I called them and they had some NOS tie rod parts. Mr Lang went back to look in the various boxes of NOS parts. I was glad to get them.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Thu Jun 16, 2022 6:29 pm
Thanks for the lead. I will check tomorrow.
1920 Dodge touring
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sat Jun 25, 2022 11:24 am
No luck with Lang's, so back to the top.
1920 Dodge touring
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jun 25, 2022 6:22 pm
Will this work.
Looks like NOS.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jun 25, 2022 7:11 pm
I also have this 2nd one
Be_Zero_Be
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Post by Ken Buhler » Sat Jun 25, 2022 10:01 pm
Bob, I don't jump ahead of anyone. I will take #1 if Mark doesn't.
Ken
Work honestly
Stay true to your word
Get the job done right
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jun 25, 2022 10:19 pm
Ken,
You are first in line after Mark.
Be_Zero_Be
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun Jun 26, 2022 1:57 am
Bob, I will check which one I will need. Ran out and looked, approx 1 -5/8 X 3-5/8 hole spacing is the one I would need. Didn't know there was a difference. The pan was on a 1925, but who know if it was original. If check is ok, send me a pm with total and address. Thank very much.
Mark
PS sorry was later in the day when I saw this. Been outside, it is HOT upstairs were my computer is.
1920 Dodge touring
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Mon Jun 27, 2022 2:12 pm
Ken,
Number one is taken.
That's the only one I have.
Be_Zero_Be
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Mon Jun 27, 2022 7:59 pm
What to give a shout out to Bob and big thank you!
1920 Dodge touring
