Ball bearing Rear end thrust FS New Price
Topic author - Posts: 4143
- Last Name: Hatch
- MTFCA Number: 49974
Here is a set of aftermarket Ball Bearing Thrust bearings. They maybe NOS no sure. There 2 of the ball bearings plate and 7 of the race plates. Ran them through the vibration tumbler to remove the surface rust. Can they be used? That will be up to new owner. $20 + shipping. Email me at address in pictures. Thanks Dan
Re: Ball bearing Rear end thrust FS
Dan, are the 7 solid plates different thicknesses? That would allow some adjustment within the pumpkin when assembling the diff centre. Just curious.
- MTFCA Number: 14383
They mount on the stock thrust washer pins. You can add shims to tighten the gear clearance.
If too tight, you get creative. remove material from the carrier or surface grind the race plates.
- Last Name: Hatch
Do not know, have not measured them. Here is copy of ad for them. Thanks to Dan T for posting it in other forum.
- Last Name: Hatch
No interest in these? Off to china I guess.
- Last Name: Hatch
Hate to scrap
