Looking for a brake pedal wrap
Topic author - Posts: 258
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
- MTFCA Number: 49710
I’m adding AC Brakes to my truck and found a photo of this pedal wrap, to connect the equalizer.
If anyone has an extra one, I would be more than happy to purchase it from you.
George Schmidt
George Schmidt
- Attachments
- 6C791936-66FA-4246-AED5-F1F927F6A2D8.png (94.88 KiB) Viewed 1922 times
- First Name: Keith
- Last Name: Gumbinger
- MTFCA Number: 4661
- MTFCI Number: 6866
Re: Looking for a brake pedal wrap
Hi George, I'm sending you a pm.
Keith
Keith
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Keith,
are they available from the vendors? i had to purchase a pedal for mine but might need another.
John
John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Hi George,
I was unable to find one of them so I made one. After that I started welding that tab & the extension on the bottom so that every brake peddle I have will work on any T I have. Do you have a set of original A-C's or a set of Larry's. Do you have a original cable equalizer? If not have you considered the Rocky Mountain equalizer or the one that the other venders offer and the peddle they offer. The up side is the hand brake applies the outside brakes as well as the park brake. In Arizona the emergency (park) brake has to be operated by a separate means from the brake peddle.
Craig, I purchased the AC brakes from Larry , along with equalizer from his buddy. I purchased the pedal with the eyelet on it but was trying to get buy, not having to switch it out.
I’m currently moving a few obstructions under the truck, so the equalizer can fit the frame.
George Schmidt
George Schmidt
- First Name: Keith
John Bevardos, I don't think they are available from the vendors. I got this one many years ago and don't remember where I got it.
Keith
Keith
- First Name: Keith
John Bevardos, I'm sending you a pm.
Keith
Keith
- First Name: craig
- Last Name: leach
George,
Did you find a wrap?
- First Name: Keith
Craig, I have a wrap that is excess to my needs and I'm willing to sell it. $25.00 plus shipping.
If you send me your email address or phone #, I'll send you pictures.
Thanks,
Keith Gumbinger 262-909-3167 cgumbinger@att.net
Thanks,
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Keith,
If Craig does not want it, I also have been looking for one.
Or I might just have to add a second brake lever on the outside of the frame.
Dave
Dave
- First Name: craig
- Last Name: leach
I weld the tab on my pedals. I was curious as to what it took to make a wrap. The first time I needed one I elected to build it some what different than the one shown, after that that I changed my M.O. just got interested it what it took to make one. I had a piece of steel that needed put away so what the hell. I was in the middle of irrigating for a neighbor so I could not go to sleep for fear of flooding things out. $25 is no where near what it takes to make one but proves I will not be manufacturing them. This is what I came up with. Craig.
- First Name: Keith
The brake pedal wrap I had has been sold.
Keith
Keith
