mainbearing linebore unit
Posted: Sun Jul 17, 2022 9:45 am
by Gene_French
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $1050 plus $150 crating and shipping in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
NEW PRICE ... this new INCREASED price reflects the current materials and shipping cost ... sadly , these cost increases and material supply issues may cause many small businesses to cease production or the supply of service ...while i do not benefit beyond the recovery of most of ,my materials cost again , i am saddened to announce this increase ,..
Re: mainbearing linebore unit
Posted: Sun Jul 17, 2022 10:57 am
by Gene_French
Posted: Sat Sep 24, 2022 11:18 am
by Gene_French
to the top again ...thanks MTFCA
Posted: Sat Nov 26, 2022 10:19 am
by Gene_French
Posted: Sun Jan 08, 2023 9:53 am
by Gene_French
Posted: Tue Feb 21, 2023 10:25 am
by Gene_French
Posted: Fri Mar 24, 2023 10:52 am
by Gene_French
Posted: Sun Apr 02, 2023 11:16 am
by Gene_French
to the top again ...Thanks MTFCA
Posted: Sat May 13, 2023 9:35 am
by Gene_French
Posted: Thu May 18, 2023 12:17 am
by Patrick Goodman
What can be used to drive the shaft?
Posted: Thu May 18, 2023 9:36 am
by Gene_French
Patrick:
this is driven by your 1/2" drill motor ... others have rigged an elaborate feed system by using a milling machine or lathe ... my design works well with a simple drill motor and hand feed ... boring bit is ground with a left hand lead ... this causes a slight resistance to the feed motion allowing a controllable feed ... you may call for additional info ... i will send an email with the proceedure sheets in an attachment ...Gene French 970-581-2808
Posted: Sun Jul 02, 2023 10:22 am
by Gene_French
Posted: Sun Oct 01, 2023 11:23 am
by Gene_French
Posted: Fri Dec 01, 2023 10:18 pm
by Gene_French
Posted: Thu Jan 18, 2024 9:55 am
by Gene_French
Posted: Thu Mar 28, 2024 10:02 am
by Gene_French
Posted: Sat Jun 15, 2024 10:09 am
by Gene_French
to the top again , thanks MTFCA ( i am on my 667 th. linebore unit since 1979 , i skipped #666 )
Posted: Sat Jun 15, 2024 3:14 pm
by Will_Vanderburg
Your products are outstanding. Just wish I could afford them.
Posted: Sat Jul 13, 2024 9:14 am
by Gene_French
Posted: Sun Aug 04, 2024 9:08 am
by Gene_French
Posted: Thu Aug 29, 2024 9:26 am
by Gene_French
to the top again ... thanks MTFCA
Posted: Mon Nov 04, 2024 2:59 pm
by Gene_French
Posted: Sat Jan 04, 2025 10:55 am
by Gene_French
Posted: Sun Jan 26, 2025 10:58 am
by Gene_French
Posted: Thu Feb 13, 2025 9:15 am
by Gene_French
have made another run of linebore units for this years sales ... will have several on display at the Duncan ,Ok. swapmeet in March ... you can save shipping on a unit and pickup at the meet ...Gene French 970-581-2808 or
gfrench1953@hotmail.com
Posted: Fri Apr 18, 2025 8:38 am
by Gene_French
Posted: Fri May 30, 2025 10:00 am
by Gene_French
Posted: Sat Jul 05, 2025 8:32 am
by Gene_French
Posted: Sat Nov 08, 2025 8:29 am
by Gene_French
Posted: Wed Nov 19, 2025 1:59 am
by dunnds
Hi Gene, My name is David Dunn and I would like to talk to you by email as I live in Australia. My email is
dunnds@bigpond.com
Posted: Thu Dec 18, 2025 10:02 am
by Gene_French
Posted: Mon Dec 29, 2025 8:51 am
by Gene_French
